1/32 Moebius Flying Sub
    Or just use tastefully added fasteners.
    I have no gaps in mine. And only 4 hard to find screws. BD
      Got any pics of them, BD? Not one photoshopped by others.
        ...that was photoshopped?
          Nuck Nuck Nuck!
          Or should I say.
          Knee Knee Knee! Lol
            Sorry,
            I forgot the photos.
            I will take them tomorrow. BD
              Here is my 4 screw method.
              Sorry for the photo size. I can't seem to get them to post larger. (Internet challenged)
              Soooo!
              Here goes.
              The first screw is in the stern or tail or whatever you call the rear end of a plane/boat thingy.
              It is above the rear screen door, and threads into a tapped piece of K&S brass strip.
              The second is under the nose and threads into a similar section of K&S brass strip.
              The third and forth screws are in the underside of the wings at the points where the stock pins align the top and bottom hulls.
              I installed a cut down brass nut in the top hull post. And drilled out the bottom post to add a countersink for the screw heads.
              I use 2/56 SS Allen head screws on the wings and tail, and a 4/40"SS Allen head screw in the nose.
              If I painted the screw heads they would be very hard to spot but I am not George and a fastener or two does not bother me.
              Any questions ask. BDClick image for larger version
ID:	128484Click image for larger version
ID:	128485Click image for larger version
ID:	128486Click image for larger version
ID:	128487Click image for larger version
ID:	128488Click image for larger version
                BD, what adhesive do you use for attaching the brass to the plastic?
                -tnx,
                Jeff
                  I asked myself the same question when I saw that. But I like the installation.
                    On this I used CA medium.
                    I only use Balsa USA CA.
                    Just make sure the plastic has good tooth. Like 80 grit paper.
                    Then clean good with alcohol.
                    I find this is sufficient for years of trouble free usage.
                    I use G/flex by the West System if it has high loads. BD
                      Thanks, BD. Will have to look into the G/flex!
                        I like modified acrylics. The advantage of using those is that they actually key into the plastic, and they form a bond stronger than the substrate.
                        I used Deluxe materials Super crylic, but other makes are out there like Stabilit express, Uhu Plus Acrylit and Devcon Plastic welder I and II. Hobbyking also sell it in small tube format very inexpensively. This glue also has a very long shelf life.
                          Stabilit Express is my all time favorite glue.
                          But sadly not available over here any more.
                          Plus it was $$$$$$$$$$$$$$$$$$$$$$$$$$$$$
                          It's shelf life sucked though. Once you opened the tube the clock started ticking. BD
                          • southern or
                            • May 2014
                            • 484
                            #133
                            Isn't that the truth with a lot of them. I've taken to lining my putties and sculpt with plastic wrap. No idea how to preserve my CA stock. Seems to last 4 months after the tip is cut.
                              One reason I use Balsa USA CA is its shelf life.
                              I have Two year old stuff as good as new.
                              Plus it seems to bond better. (I am in no way connected to the co) Ha!
                              BTW I keep mine in the fridge till I open them. Not sure it helps or not.
                              I have heard pros&icons. BD
                                Got the lower intake cleaned up between the strakes (am I using that word correctly?).
                                Also fitted the aft door and attached the hand wheel. Undecided about whether to glue it shut or activate the hinges.
                                Installed two stainless 4-40 x 3/8 pan phillips machine screws to secure the floor piece in the hull. I like the idea of being able to remove it.
                                A shot through the windows with the seats and dash panel. The window pieces were a bit tricky to fit with the bow piece glued in.
