1/72nd Revell Gato Wolfpack
    • 942
    #46
    Oops, forgot: Eventually I'll be checking to see if one or more of the Evergreen corrugated styrene sheets (like I used for Seaview's non-skid/safety track) might be employable as 1/72 wood decking to replace the areas Paul brought up as being too much metal for particular boats.
    JeffP
      • 880
      #47
      Not my boat but cool. Might get some Ideas from this guy, "Channell".
      Easy on that Green Tea JeffP!
      I'll drink to that! (hic) JeffP
      Scott T
        That guy has a super looking project going, Scott!
        Status Report: Been up to my elbows in SCR work and new school year. However, I did steal a few moments here and there to scribe Flasher's MBT openings (don't tell LaRue). Pics to follow when I get a chance. Harder (Porteous) is busy accumulating aftermarket parts for his build and doing research. And doing work on his fleet as is Trigger (Kisler) to prepare for Sun N Fun 2012.
          hmmm.....there are probably enough folks in this SC wolf pack build to justify developing a PE set of items for this kit. (different than the Eduard PE kits)
          Any interest?
            I think a portsmouth/Mare Island limber hole set with rivet detail, ala the Eduard fuselage panels, would be gold. An early war metal upper deck wouldn't be bad either.
              • 2347
              #51
              Any interest?
              Simple answer, Yes!
                AMP was developing a Portsmouth limber hole PE set several years ago but dropped it. Maybe they would be willing to share what they worked up?
                • kerry addington
                  • Nov 2005
                  • 87
                  #53
                  I assume you guys are aware of this resource?
                  -Kerry
                    Absolutely. Great stuff. Tom already has their Silversides set which he's modding to represent Trigger.
                      • 880
                      #55
                      Working on some torpedo door activation. Started with some paper and now cutting up a
                      milk jug to make the arms.
                      Pull the arms to the rear to rotate the doors.
                      Scott T
                        • 2347
                        #56
                        Way to go Scott! I love it! What are your thoughts on how you are going to make them work?
                          • 880
                          #57
                          I haven't invented that part yet. Was thinking of glueing magents in to the end of the arms
                          that is pulled by a servo rod. The magnets should give it a littlt play I hope.
                          Scott T
                            • 848
                            #58
                            Someday, USS Hake, SS-256 will be added to the fleet. She finished the war as a Barge Buster, 2 5"25s, twin 20mm fwd, 40mm aft. Loaded for bear!! Minimal mods required, as she was an EB boat. Pride in the company, as it were!
                            B^)
                              Cool, Bill. that should be a very unique look. I got the first complete pass on scribing the MBT floods done and am opening up the proper ones that didn't have the door. Will try to post a pic. She looks much better with all the business on her bottom.
                                Here's a shot of the scribing and drilling of the MBT floods, etc. I used the Nautilus "Pre-War/Early Gato" template to mark the holes then used the plastic stencil as a guide.
