1/72nd Revell Gato Wolfpack
    • 947
    #46
    Oops, forgot: Eventually I'll be checking to see if one or more of the Evergreen corrugated styrene sheets (like I used for Seaview's non-skid/safety track) might be employable as 1/72 wood decking to replace the areas Paul brought up as being too much metal for particular boats.
    JeffP
      Not my boat but cool. Might get some Ideas from this guy, "Channell".
      http://www.shipmodels.info/mws_forum...06287&start=20
      Easy on that Green Tea JeffP!
      I'll drink to that! (hic) JeffP
      Scott T
        That guy has a super looking project going, Scott!
        Status Report: Been up to my elbows in SCR work and new school year. However, I did steal a few moments here and there to scribe Flasher's MBT openings (don't tell LaRue). Pics to follow when I get a chance. Harder (Porteous) is busy accumulating aftermarket parts for his build and doing research. And doing work on his fleet as is Trigger (Kisler) to prepare for Sun N Fun 2012.
          hmmm.....there are probably enough folks in this SC wolf pack build to justify developing a PE set of items for this kit. (different than the Eduard PE kits)
          Any interest?
            I think a portsmouth/Mare Island limber hole set with rivet detail, ala the Eduard fuselage panels, would be gold. An early war metal upper deck wouldn't be bad either.
              Any interest?
              Simple answer, Yes!
                AMP was developing a Portsmouth limber hole PE set several years ago but dropped it. Maybe they would be willing to share what they worked up?
                • kerry addington
                  • Nov 2005
                  • 87
                  #53
                  I assume you guys are aware of this resource?
                  -Kerry
                    Absolutely. Great stuff. Tom already has their Silversides set which he's modding to represent Trigger.
                      Working on some torpedo door activation. Started with some paper and now cutting up a
                      milk jug to make the arms.
                      Pull the arms to the rear to rotate the doors.
                      Scott T
                        Way to go Scott! I love it! What are your thoughts on how you are going to make them work?
                          I haven't invented that part yet. Was thinking of glueing magents in to the end of the arms
                          that is pulled by a servo rod. The magnets should give it a littlt play I hope.
                          Scott T
                            • 854
                            #58
                            Someday, USS Hake, SS-256 will be added to the fleet. She finished the war as a Barge Buster, 2 5"25s, twin 20mm fwd, 40mm aft. Loaded for bear!! Minimal mods required, as she was an EB boat. Pride in the company, as it were!
                            B^)
                              Cool, Bill. that should be a very unique look. I got the first complete pass on scribing the MBT floods done and am opening up the proper ones that didn't have the door. Will try to post a pic. She looks much better with all the business on her bottom.
                                Here's a shot of the scribing and drilling of the MBT floods, etc. I used the Nautilus "Pre-War/Early Gato" template to mark the holes then used the plastic stencil as a guide.
