1/72nd Revell Gato Wolfpack
    • 849
    #526
    Tom,
    That's my way of thinking, especially on these old war-wagons! Build it, have fun, with it, be happy!
    B^)
      I was confused, Jeff. I thought by "chin" you meant the mods to the superstructure forward of the bow plane wells that Tom and I did for the Portsmouth plans. The chain locker drains, shown in your most recent image and positively identified by Bill earlier in this thread, and confirmed here again, should indeed be there on Harder.
        Look at the guy riding the bow in the image. Is he having fun or what?
        Here is the Cod on the initial launching, I do not see the bow holes in her.
        [ATTACH=CONFIG]3304[/ATTACH]
          • 849
          #529
          Paul,
          They are there, but we can't see them. The holes are small and on a curve in the lower hull, as you know. You won't see them in the launch photo as they are hidden from view by the angle. With this low angle, almost parallel, they are hidden. If you increased the angle on the bow (becoming more perpendicular) you would see them down there. They might not be the full pattern shown in earlier pictures in this thread, so that could make them harder to see, also. I have a drawing for a boat with many fewer holes than shown in those pictures. Still drains, but not as quickly. B^)
            Makes sense to me, Bill.
              • 942
              #531
              It's settled then. I'll do those holes. I think they really look cool and authentic and "of the era" -- and, dadgummit, actually kinda fun to install...though I may be proven wrong about that.
              A package arrived from Shapeway today: my perfect little 20mm's on their correct tripod-type mounts...and with Harder blast shields already in place! Photos another time. (I'm home quite sick at the moment.) My intent is to beef them up a bit with some PE parts to make them more robust. It may take them out of scale a little, but they shouldn't break as easily.
              Green Board, gang,
              JeffP
                • 880
                #532
                Jeff, An idea for installing the holes is to print dot pattern on a sheet of paper. Then cut a piece of plastic milk carton
                and tape the paper to it. Drill the printed dots into the plastic on a flat surface. Then use the plastic template to tape to
                the hull to guide your drill bit. Use for both sides.
                  • 942
                  #533
                  Indeed a good idea, Scott, but I have the same PE hole pattern Paul and Tom have, and can use that as my drilling template. Actually, unlike what they did, I was contemplating trying to fair the actual PE pieces into the hull itself, with the area behind it/them opened up to receive it/them. We'll see; and I'll need to practice the process on some scrap styrene first, to see if I can achieve a clean enough look.
                  Can't do anything at the moment though -- far too sick. Sure could use a harmonica serenade (you shall forever be associated with that hyper-fun moment aboard Batfish, my friend!).
                    JeffP,
                    I did the PE faired into a conning tower for my Type II build. It was one of those large amount of very tiny holes...and this in 1/32nd scale! Well worth the effort.
                    -JeffL
                      • 942
                      #535
                      Will do, JeffL.
                      Just tried to post a video link to Vimeo (the format of which the forum says is supported) of Scott T's claim to fame, mentioned above, but of course it's not working. SO damned frustrating!
                        • 942
                        #536
                          • 942
                          #537
                          Oh-KAY! Apparently the forum likes YouTube better!
                          Enjoy, guys -- and thanks again, Scott! What a great memory...
                          JeffP
                            • 2349
                            #538
                            I am curious now, I looked through the plans I have, but none show the chain locker drain. Would someone be willing to share with me what they have?
                              • 880
                              #539
                              Thanks Jeff. I did not know that video existed.
                                • 942
                                #540
                                Wish it had been the whole song, buddy, but you pulled it on us as a total surprise so I wasn't ready to shoot!
