July 4th ======================
I had about 20 minutes out in the shop before other stuff happens.
So I measured the 2 dog bone extensions.
I need to shorten the dog bone by 7/8".
Grind off the heads of the brass pins.
With a piece of 1/16" brass rod, I tapped the pins out on one end leaving he other end intact.
I need 2" end to end on the dog bone.
Mark the tube and cut with grinding cutoff wheel.
Well that did not go well.
I cut on the wrong side of the mark and my tube is too short.
I will have to make another tube.
Looked around t find I did not have a length of the tube the long enough.
I will have to pick some up later.
On to the second dog bone.
Using tape to mark the tube, I got a good cut with the correct finish length.
I installed the dog bone end in the tube and drilled and pinned it in place.
Test fit in the hull with the cylinder in place with end cap.
There is not quite 1/8" movement between the dog bone connectors.
The propeller turns easily.
I have a good dog bone.
I have an appointment in town tomorrow so I will go over and see if I can find the more tubing after it.
Have a 1/2" sample to take with me.
