June 20th ======================
Not much y
Today I was still working to get the motor bracket straight so the motor runs free.
Well, I have been putting pressure on it here and there.
Finally I broke it back were the servos mount to the bracket.
No way to fix it so I have to make another one.
Out tot he tool shed and cut a piece of aluminum sheet.
Measure out where the opening for the motor and servos go.
There is also an opening for the wheel collar grub screw that hits.
Got the plate cut out of the big sheet.
Using a 1/4" mill bit, I straightened the free hand cutting edges.
Well almost.
I was about 3/8" from finish when the bit grabbed and moved the plate binding the bit until it broke.
The bit was my dad from about 1946.
So now I have to find a new one.
Moved on to using the Dremel grinding wheel to cut in to the plate so I can knock out the openings.
As I started the first cut, BANG! the wheel disintegrated.
Looked to put another wheel on and there it is.
An empty grinding wheel box. (that's just not right)
I finish measuring for the opening and bolt holes and set the aluminum piece down on the bench.
Done for the day before I get hurt.
Tomorrow will be go to town and find grinding wheels and a mill bit.
Only good thing about all this is I can make the opening for the motor small front to back by 1/4". (more room in the cylinder)
Oh. . . I will not be mounting the front rear tray to the back rear tray.
While fitting the motor tray in an out trying to align it, I noticed the air pump tray will bounce up and down with the motor rotation because of the1/64"-minus offset.
But while turning the cylinder over and over checking clearances, I see that I can make 2 aluminum strips to go from the tray under and around the motor to the air pump tray.
The motor will not effect the air pump tray and the 2 trays will be solid to the end cap. (they can move independent of each other)
So I made 2 strips to mess with and see if this works out.
Weather says tomorrow and next 4 days the high will be in the 90s so I should be able to get more time in the shop.
Drilled holes in corners of the openings.
Not much y
Well almost.
