With the carpenters glue now
With the carpenters glue now dry, I took the sail to a large disk sander to bring it to shape. This was done with the sail upside down on the sanding bed, using the 1/16" ply base as a guide for how much material to remove. I then put a tilt on the base for the sander and repeated the process, this time leaving a slightly beveled edge on the sail. A quick pass with a fine-grit paper loaded block sander, and here is the result]http://www.subcommittee.com/forum/new_sail_blocks_sanded.jpg[/img]
The next task was to radius the upper corner. I did this by eye last time, and spent an inordinate amount of time trying to get it "just right", which it still isn't. This time 'round I've decided to make a radius sanding tool to get the edge exact the whole way round. The tool itself is dead simple to make, and worked really well. (Moral here- It's definitely worth spending the time to make tools and jigs to accomplish even "simple" tasks.)
Step one was to make the "base" for the tool. It's nothing more than three pieces of lite-ply glued together to look like a corner-sanding tool. (This part of the tool was built in place, but first I placed a square of some plastic bag material underneath so I didn't inadvertently glue the tool to the sail as I was making it!)
Next for the radius- I found a piece of large diameter brass-tubing that looked like it would be just perfect for the job. I gave the tube a quick buff with some wax and PVA in preparation for use as a radius mold. Next I gooped some Icing into the corner of the radius tool, and sank the brass tube down into it.
Once the Icing kicked off the tube was removed leaving a perfectly round surface for creating the radius.
Almost done now- I 3M77'd a piece of 150 grit paper into the radius. Not so clearly visible, where the sanding paper isn't I placed some clear packing tape to help the tool to slide along the surface of the sail.
And to set the tool in action. The keenly observant will notice that this radius below looks a bit bigger than what's shown above. That's cause it is- When I completed sanding the radius the first time it looked a little too small, so I simply pulled up the sanding paper, found a slightly larger diameter form (this time it was a small diameter aerosol can) and molded the new radius into the same tool. Here's the result:
And here is a glamour shot of the new sail in it's place...
