Sam,
So true. Thanks a bunch
Sam,
So true. Thanks a bunch Sam.
Matt,
I plan to use a technique I've used for my jets in the past and it works well. I hope as well on subs. If you go to my web site www.sneill.com and then to the planes section, click on TA-183 you'll get the idea.
Drafting tape and other types of tapes are used to create the indents with a lot of heavy primer coats over them. Once the tape is removed you get some very deep scribes that can be lightly sanded before molding.
As the details on the the type 17 are rather sketchy I can get away with a lot.
Hard to tell whether this later boat used the same type of construction methods as the type 7. Rivets I may leave out because in all the pictures I have of the real boat I can't see them. Maybe all the panels were welded by this point. If someone knows please ring in here please.
Myles,
Thank you very much and I'm glad to see your learning from this and plan to do your own boat. It's a pleasure I'm sure you will enjoy very much. I will endeavor to keep all the little details in this thread as is possible.
One thing I need to point out which has become apparent by my email. When wire cutting the sections some folks asked the question if they remove the formers does that change the size of the section?
What I've done here is to break up a side view to scale of the boat with all the stations marked.
Next you cut a block of foam out to the profile and mark all the stations. Cut them up. Then placing the correct formers either side you can then wire cut the section. Remove the formers and your done. Once they are all cut they go right back together again perfectly except now you have something that looks like a hull.
Sam,
Matt,
Myles,
