A servo tester.
Why, no I do not have a servo tester.
I do have 2 Tx and a hand full of Rx on the work bench.
Just a matter of tuning the Tx to the Rx of choice and having a charged battery.
The Futaba 9CAP Tx is computer controlled and I can turn any channel from zero to 130 % travel.
I try to not break things, I start at 5% then while everything is on I can turn the percentage up at the Tx to adjust the needed throw.
My other Tx do not have this feature.
So basically it requires a little more work to setup.
I will also have to adjust the rudder servo and speed controller because I do not want this boat going very fast at full throttle and I need a little more than 90 degree to each side.
I do draw on paper the full size linkage and then see how much servo throw I need and this gives me the location of the holes in the horns.
It is usually close enough with a little adjustment to the Tx.
My Skipjack was a lot of fun because the Tx is shadered with the Aklula II and all linkage adjustment is physical.
The Akula II was setup first to the Tx.
Then I had to match the Skipjack linkage t work on the same Tx.
No computer in that Tx.
If I make it to easy, what fun would that be! <GG>
