November 29th =================================================
Today, I fitted the rudder post in to the stern rudder through tube.
The glue I use to install the rudder through tube, expands.
It apparently expands enough to change the shape of the 1/2" brass tube.
I had to use a Dremel 1/4" sanding drum and a couple of files.
Round and half round to get the tube back to round.
Polished it and the rudder post, several times until the rudder turned easily.
Cleaned up the 2 spacer brass rings that go between the hull and the rudder and between the hull and pulley.
Drilled the pulley and rudder post for a through pin of 1/16" rod.
Also drilled the pulley for the cables but it is on the front side.
Sat down on my milk crate and with Exacto knife, I removed the vinyl letters.
I am actually surprised how well they came out.
The vinyl letters are 1/2" tall.
I have removed the rudder and I am preparing the stern block for priming and painting.
There is some glazing to do.
I have jury duty tomorrow, so I plan to put the glazing on today and let it dry until I get done with jury duty.
