Alexander Engel TK-208 Russian TYPHOON Submarine build
  • u-571
    • Dec 2008
    • 110
    #46
    can anyone direct me towards getting some help. I need a decal made otherwise I may just have to hand paint it.
    what I need is a decal of some sort that goes in front of the conning tower on this typhoon submarine its a Russian logo needs to be around not exactly 1' 1/4 inch long 1' inch wide its going to be a small Decal can anyone help
      If a one off decal is not doable (I have no idea of that), another possibility is inkjet printing on rice paper. I have used it to put pictures on kayak paddles. It needs to be done with a printer that uses pigmented inks, not dye based or it will bleed. The rice paper is very thin, so tape a section to a piece of normal letter size. After printing, trim around the logo, and use thin resin to apply it like you would glass cloth, the paper absorbs the resin and goes transparent.
        Is that a typo or does your decal need to be 15" x 12"?
        That is one big decal! Testers has a decal kit
        You might be able to do it. I have yet to use this so maybe others can speak up if it is good or not.
        Or I searched on google for decal maker and this came up:
        https://www.stickeryou.com
        Again your mileage may vary.
        • u-571
          • Dec 2008
          • 110
          #49
          thanks for the help yes its a typo its just a small decal I fixed my typo
          • u-571
            • Dec 2008
            • 110
            #50
            it looks like a water transfer I think I'm going to do but they say to use a laser printer give's a better print result link below I was impressed when i saw the YouTube video
              I've used the Testers decal system. It works very, very well and is quite easy to use.
              • u-571
                • Dec 2008
                • 110
                #52
                Thank Jeff
                I'm sure there are other way of doing it but I think the tester decal system will work great since its a small decal in front of the coning tower. I will also spray it with a flat sealer spray to make it water proof.
                  Definitely use the decal-specific sealer. I used it on my Type II U-boat conning tower and it's held up without any sign of degradation.
                  • u-571
                    • Dec 2008
                    • 110
                    #54
                    thanks Jeff Im going this route . I will post pictures of my steps when i do it
                      The only issue with decal paper (clear, I'm assuming), is that on a black background your colors won't come through. If you go with white decal paper, you'll need to be utterly precise in cutting them out so as not to get a white border around the details.
                      Bite the bullet and do it right. Get with Cindy from www.aeroloft.com and send her your artwork. They'll turn around a proper dry transfer quick and for a decent price. You spent $3k(ish) on your sub. Don't cheap out on something that will be sitting front and center for the rest of its life!
                      Bob
                      • u-571
                        • Dec 2008
                        • 110
                        #56
                        Bob
                        Oh no I wont take any short cuts . I thought using water transfer was the way to go. But if theres someone that can make it for me perfect. Yes I will go that way I will get in contact with Cindy
                        thanks bob
                        • u-571
                          • Dec 2008
                          • 110
                          #57
                          I just sent 3 pictures to Cindy at www.aeroloft.com we will see how much for the decal then I will go from there. l think bob is right I don't want to take any chances I want it perfect. I think some one that does it for a living will do a better job then I can. I will keep everyone up to date on my findings I hope its good . The water transfer is good but I will have a black background so I think the colors may not be that vivid . That's the reason I'm going with Cindy I sent her these pictures she should be able to work with these to get the right size and shape of logo . thank you to all of you giving me ideas and choices much appreciated
                          Jim.
                          • u-571
                            • Dec 2008
                            • 110
                            #58
                            I have some one In Arizona that is making me the logo . She's does custom hand work she draws them out precisely Then sends it to a vinyl decal machine . When i receive it I will post pictures .
                            thanks for everyone's ideas and helping me out to decide what route I wanted to go . The place is called http://www.aeroloft.com/ Cindy is her name .
                            • u-571
                              • Dec 2008
                              • 110
                              #59
                              I NEED SOME HELP ANY ONE ! I posted a picture of a watt meter that was suppose to work for 6 volts system because my typhoon is a 6 volt system. Well it only seems to work on 12 volts only does not even glow light up does nothing on 6 volts. I want some thing that works .Can someone send me a link of a 6 volt meter that works for sure.
                              much appreciated
                              thanks Jim
                              • u-571
                                • Dec 2008
                                • 110
                                #60
                                I was told what the problem was there is a outside small power supply, small little pins that need to be powered up for the meter to turn on . normally you need to do nothing if the power is over 12 volts In this case 6 volts is to low for the screen to turn on with out some help. I now can now use it for a 6 volt system . I had no instructions on this unit that is what the real problem was
