Revell VIIc shipping in holland
    I am having difficulty figuring
    I am having difficulty figuring out how that frame around the edge of the inner tower walls could be right. True there were a number of elevated steps or platforms for the lookouts to stand, but not a continuous ledge like this!
    Does anyone have any idea when these kits will kit North America?
      #32
      jeff,
      I believe you have
      [color=#000000]jeff,
      I believe you have "vom original zum modell]
        There is definitely a (separate)
        There is definitely a (separate) step (up) on both the left and the right.
        Good idea about the AA tower. I'll send you two photos.
          #34
          Ok, yet another anomaly (I
          Ok, yet another anomaly (I think)
          I believe (from the books) that the attack perisicope
          housing should be about as high as the sides of the tower.
          have a look at the kit
          for comparison.
          Ronald
            The tops of both periscope
            The tops of both periscope 'shears' should be approximately the same height as the tower walls.
            It's beginning to look like the tower may require the most work in the entire kit!
              #36
              well.....
              do not underestimate opening
              [color=#000000]well.....
              do not underestimate opening the floodholes
              have a look at the improved aft periscope housing and note also the first attempt
              to open up the air duct.
              the shape of the air duct and the shape of the "chimney"
              are documented in the original building plans included
              in "vom original bis modell ]
              Edited By raalst on 1072216549
                #37
                two new photo's.
                here
                two new photo's.
                here is the shape of the "chimney" (fairing ?) on the
                right side of the tower.
                and here is the improved air duct
                If you look carefully you know where i got the grating from..
                The metal grating was sunk into the plastic by
                *careful* heating with a soldering iron. works well.
                also, the air duct was made slimmer at the top by sanding
                the side of the separate air duct part. hope you know what I
                mean.
                The attack periscope housing is coming along nicely too.
                Is there anybody with more detailed photos of the forward
                area of the inside of the tower ?
                Edited By raalst on 1072268428
                  Ronald-
                  nice job on the periscope
                  Ronald-
                  nice job on the periscope housing...it's looks much more correct witht the height you have given it.
                  I see that you have used a metal strainer to create the exhaust covers...I have used fiberglass window screen in the past for this (and for intake screens on model tanks...) In fact, there is material sold here for keeping weed out of flower beds that has a very small tight weave that would probably work for a small are such as the tops of the ventilation stacks.
                  The UZO stand needs to be high enough so that when the binoculars were atatched to the base, they would be above the height of the front tower wall.
                  Jeff LaRue had a photo (I think) of the front tower wall. Also, the detail from the Accurate Armour tower should help here, right?
                  Thanks again for posting these shots for us Ronald. It's nice to see the model evolve from a box of parts...
                  cheers,
                  Sam
                    #39
                    I found some site which
                    I found some site which dared publish (part of) the
                    building plan from the revell kit
                    have a look at http://schnellboot.net/div/andere/ub...pVII/revell72/
                    again, in german, but the pictures do the talking.
                    frohe weihnachten/merry christmas
                      #40
                      some more info on the
                      some more info on the kit.
                      The floodgates underneath the
                      tower are not correct, at least for U203.
                      (U-boats in action, photo on Page 22)
                      the floodgates on the kit
                      the photos I have available suggest the gates are also
                      grouped in pairs of two being spaced close® together.
                      I will leave this, correcting it might ruin more than it would
                      do good.
                      The upper row should have 4 gates more than the lower
                      row on both sides. two are missing.
                      I made them with a heated screwdriver, but that
                      turned out less than perfect.
                      Edited By raalst on 1072558337
                        That, I believe, is a
                        That, I believe, is a yard-specific variation.
                        The free flood vents under the bow are another of those types of variations.
                          #42
                          a few pics of the
                          a few pics of the floodholes. opening them up certainly
                          improves the appearance of the hull.
                          fore
                          aft
                          the ones in the middle
                          and how I tackle opening them
                          the other halve still to do, as well as the deck.
                          now do I *reeeeally* want to do this ?
                          Edited By raalst on 1072713769
                            Hi Ronald,
                            ...'round about now, I
                            Hi Ronald,
                            ...'round about now, I suspect that your hand is getting cramps from all that fine detail work....
                            It looks very good and clearly worth the effort!
                            Regarding the deck - you may want to hold off on opening all those deck slots. I'm told that someone in the U.K. is going to be offering an aftermarket etched brass deck for this kit. (I know since I contacted them about an arrangement to use my drawings. They declined.) If they do not come out with one soon, there are some folks who have been (politely) hounding me to offer one based on my existing drawings.
                              Hi Ronald,
                              If they do
                              Hi Ronald,
                              woof woof.
                              Are you talking about White Ensign (I think that's their name...)
                              Are they going to do a conning tower floor as well?
                              Sam
                                #45
                                I know there will be
                                I know there will be a host of addons out for this kit.
                                But since I feel I am (up till now) the first one reporting
                                on it, I'll continue with what I've got.
                                I'll make a second one, I expect (how about radar and
                                snorkel (it's a dutch word, so it is spelled correctly
                                Opening the deck goes better than expected, but requires
                                a certain amount of madness...(hollow laughter)...
                                anybody working on an interior for this kit ??
                                does anybody know what these are ? they live just aft of the dive planes.
                                as far as I have photo's it is suggested that these things
                                should be holes. but on the kit they stick out of the hull.
                                Edited By raalst on 1072777851
