Revell VIIc shipping in holland
  • brad
    • Jan 2004
    • 18
    #61
    Hi Jeff & Ronald,
    Thanks for
    Hi Jeff & Ronald,
    Thanks for the info.
    Ronald, as far as lengthening the periscope base and the UZO (from the pic of the your latest tower), how did you accomplish this? Was it with discs of sheet styrene or did you use a form of putty?
    Jeff, Maybe when I retire, will I tell a few stories, and yes I have a few during the cold war that are interesting.
    Cheers
    Brad
      #62
      Brad ]
      [color=#000000]Brad ]
      • brad
        • Jan 2004
        • 18
        #63
        Ronald,
        Thats just too awesome!!
        I think
        Ronald,
        I think everyone has built a tank or two haven't we
        Are limber holes the same as Flood Holes/Gates? I have heard that if you drill out the flood holes, you should be able to see through them, but you should just see through to the inner hull? Also, the limber holes on the bow are the only ones that you should be able to see through?
        Thanks again!
        Brad-U-boat challenged, but I can tell you some neat stuff about the Akula & Typhoon
          #64
          well, we build these too,
          well, we build these too, don't we ?...
          basically, you don't see anything thru the limber holes,
          but I feel "real dark" beats "painted black" any time.
          I plan to put some hint of a pressure hull inside,
          like a roll of black carton or something.
          I am not yet clear on a diorama or not, so maybe
          I will put some more detail around open
          hatches. But first I want to finish the tower..
            • 1325
            #65
            <snip>Are limber holes the same as Flood Holes/Gates? I have heard that if you drill out the flood holes, you should be able to see through them, but you should just see through to the inner hull? Also, the limber holes on the bow are the only ones that you should be able to see through?
            <snip>
            Brad- if you get your hands on one of the references listed, there will probably be a side view diagram that shows the actual pressure hull shape inside the outline of the boat. You will see that there is lots of outer casing that makes up what you know as a type VII U-Boat shape.
            So yes, limber holes are same as flood vents (but grates may be openings for access to hatcheds underneath, but basically the same thing), and there are some places, especially up near the bow, where you would be able to look through both sides. However, as Ronald has stated, the pressure hull would be visible through some of the middle holes. I would find some way to open that long slot along the top of the saddle tanks by reinforcing internally; I think it would look funny if you opened all the flood grates and left that slot painted black.
            cheers,
            Sam
            • brad
              • Jan 2004
              • 18
              #66
              Thanks very much Sam for
              Thanks very much Sam for the info. I am working on getting the Anatomy of the Ship Type VII U-boat book. Being married, it takes a bit of convincing. I didn't mention this below, but I build mostly WWII aircraft, and to start building up references for U-Boats can be tricky.
              Brad
              • wolf pack
                • Jan 2004
                • 28
                #67
                Hi Guys,
                This is Thomas.Im watching
                Hi Guys,
                This is Thomas.Im watching your progress with great interest,im building ww2 airplanes like Brad but i also like ships,love u boats and im in love with flower class corvette.Oh yes i have the revell flower class and im working on it.I start building the u boat and a guy from another forum gave me your link here.I want to thank Ronald for the great info and help he is giveing to us.
                I have done so far some modifications on the tower,i have add new torpedo tubes and change the railing on the tower with 04mm steel wire.You can see my model in
                Just type on the search window "u boat in progress" and you will see some photos of my model so far
                Regards from Greece
                Thomas
                Edited By Wolf Pack on 1073841991
                  #68
                  wolf pack,
                  your periscope
                  wolf pack,
                  your periscope is a marvel !
                  other people,
                  please be sure to check that link above !
                  brad,
                  While waiting for the book,
                  do not underestimate the Internet !
                  have a look at
                  The U-boat War in World War Two (1939-1945) and World War One (1914-1918). Over 30,000 pages on the officers, the boats, technology and the Allied efforts to counter the U-boat threat.
                  http://5533.rapidforum.com/ (free registration reqd.)
                  ( vary the numbers, i.e. u995-003.jpg etc. or start with
                  the site name, click spots then other spots)
                  Some understanding/guessing of german required..
                  Of course, our site www.subcommittee.com has a decent
                  collection of links and photo's as well.
                  and of course use www.google.com and be creative in
                  the selection of words in your search.
                  happy browsing !
                  sadly, my ISP has a problem and therefore I cannot publish
                  the pictures of the tower insides (yet).
                  a bit more patience, please...
                  Edited By raalst on 1073859250
                  • wolf pack
                    • Jan 2004
                    • 28
                    #69
                    Hello,
                    As i said before im
                    Hello,
                    As i said before im building ww2 aircrafts and thats why im very sensitive with the propellers.Im trying to give the same ephasis on my boat propellers as well.If you take a closer look on the revell props you will see that they are not very accurate "at least in my opinion".They are 22mm in diam. and i try to find somethink better in the market.I found a company named raboesh that have brass propellers for r/c boats.In their range they have 20 and 25 mm props that i think they will add to the revell kit.I have order the 20mm A type M3 (item number 146-01 146-02).
                    Raboesh page is]http://home.concepts-ict.nl/~raboesch/english/cat2_index.htm[/url]
                    I will post a photo of them when i receive them in the end of the month i hope.I have allready a raboesh prop 35mm for my flower class corvette in 1/72 and i can only tell you that they are 100% fine products.So if you are interest you can contact with them and order.
                    Ps
                    If you havent allready visit the www.airfan.de just go and check.
                    many regards
                    Thomas
                    • tk-7642
                      • 38
                      #70
                      The best book I have
                      The best book I have ever seen on U-boats is called The U-boat by Eberhard Rossler (in English).
                        • 1325
                        #71
                        I remember reading somewhere that
                        I remember reading somewhere that the props on Type VII U-Boats were not brass or bronze and therefore not that color; they were actually cast of another material and a dull gray color. Can anyone confirm this? If you are going for strict realism, that shiny, beautiful prop would then have to be painted over with a dull gray color.
                        I honestly don't remember where I read this...hopefully, someone out there knows...
                        cheers,
                        Sam
                          I believe it was Rossler's
                          I believe it was Rossler's book that mentions the steel props....
                          • koeze
                            • May 2003
                            • 204
                            #73
                            I think this should erase
                            I think this should erase all doubt.
                            Photo of last surviving Type VII (C/41)
                            Looks bronze to me.
                            EJK
                            • wolf pack
                              • Jan 2004
                              • 28
                              #74
                              Well the props seems to
                              Well the props seems to be bronze,maby mixed with something else.A friend of mine have a reall boat and i remember the props are very shiny but after a while they are like the one in the photo above.Besides i don’t planning to put them shiny as they are.There is a liquid that you put metal thinks inside and oxide them,i just have top check it out first and i will tell you.Actually i will try with battery acid or some other toxic thinks i have and see what will happens.I hope they dont explode on my face!!
                              Regards from shiny Greece
                              Thomas
                                #75
                                the server I store my
                                the server I store my files (pictures) on seems unavailable
                                still.
                                This would mean all links I posted will currently not work.
                                Sorry.
                                If somebody has some reliable space to spare, I am game!
                                Ronald
