    I use Evercoat polyester glazing putty. It's similar to Bondo. It sets up in minutes and sands very well. It adheres to fiberglass very nicely.
    • profesorul
      • Apr 2014
      • 106
      #137
      Many Thanks ,
      I have to Run to work .
      MARIUS
        I've been trimming the boat out a bit. I had to ad quite a bit of lead weight to the stern to get the COG correct, and in turn a lot of foam to counteract it.
          The basic building and trimming is over. Time for some paint.
          Upper hull black, lower hull a close match to anti-fouling red.
          I'm taking some liberty, here. On the upper hull, I've masked over the scribed areas and cut the shapes out with the scribing tool. Then I blasted it with some dark grey paint to make these areas stand out even more.
            Draft markings
              Buoy is in place
                One last dip in the pool to make positive everything is square. the surface and submerged trim are where i want them. with the OTW cylinder i can hover the boat right on the edge of the sail.
                  Looks great! Well done Eric.
                    • 2357
                    #144
                    Dog-gone pretty!
                    • profesorul
                      • Apr 2014
                      • 106
                      #145
                      Absolutely Great . Congratulations .
                      We waiting for a Maiden Voyage , Video Clip .
                      MARIUS
                      • tsenecal
                        #146
                        1 month....
                        you started this thread on march 16th... that is one month from the start of this build to today... amazingly fast as well as amazingly good looking.
                          Some shots from the Akula's maiden voyage
                            A couple videos of the Akula
                              Fantastic work, Erich! Well done!
                              • profesorul
                                • Apr 2014
                                • 106
                                #150
                                EXCELLENT Job . Well don .
                                MARIUS
