New project
  • drschmidt
    • Jul 2014
    • 424
    #106
    Re: New project
    First set of milled structure parts arrived and it looks quite good:
    And as I had the pleasure to spend last week sick at home I tried what my CAD offers in terms of making sketches for build instructions…...looks good][/url]
    • profesorul
      • Apr 2014
      • 106
      #107
      Re: New project
      HELLO , @ DrSchmidt
      Is an ingenious way to shrink the space occupied by the components , and also the give them stiffness .
      Why is it necessary to be so thick material ?,
      The submarine does not get too heavy ? ,
      From what material are made the parts ? ,
      Same method it's used by ENGEL for their models .
      It is quite professional .
      MARIUS
      • drschmidt
        • Jul 2014
        • 424
        #108
        Re: New project
        It's 5 mm PVC. I guess similar to the Engel boats, actually designed for an Engel tank, but the overall design is mine. PVC is not really heavy and as everything has to be connected by thread rods, I prefer thicker material, so that everything gets stiff and does not bend under its own weight. Too heavy? We'll see.....it's a prototype.
        Cheers Andreas
        • drschmidt
          • Jul 2014
          • 424
          #109
          Re: New project
          Even if it doesn't look like it.....this is going to be the mould for the rear bulkhead:
          • drschmidt
            • Jul 2014
            • 424
            #110
            Re: New project
            This will be the motor feed through of the Nautilus. Basically it's an advanced version of the ones I have in my U-1. Took a while to find a workshop that is now doing the parts. I guess I'll make some more.... The parts will be made of bronze and brass, it will have a ball bearing and an ID 4 mm rotary shaft seal. It will be attached to the rear bulkhead via a simple M16 fine thread and sealed via an o-ring. Advantage: only one hole in the bulkhead, no additional holes that have to be sealed. And it saves so much space in your boat....
            • drschmidt
              • Jul 2014
              • 424
              #111
              Re: New project
              And the first half of the mould for the rear bulkhead...
              • drschmidt
                • Jul 2014
                • 424
                #112
                Re: New project
                decks have arrived.....eastern present
                • profesorul
                  • Apr 2014
                  • 106
                  #113
                  Re: New project
                  Was deleted because I posted twice .
                  MARIUS
                  • profesorul
                    • Apr 2014
                    • 106
                    #114
                    Re: New project
                    HI @ DrSchmidt
                    OUTSTANDING work as everything You do .
                    Can You tell me Please what is that "red and light blue" piece and where is situated the ball bearing ? .
                    Is correct my assumption there are some Simmering/s ?.
                    THANK YOU .
                    MARIUS
                    • drschmidt
                      • Jul 2014
                      • 424
                      #115
                      Re: New project
                      Blue: ball bearing
                      Red: drive shaft seal (=simmerring)
                      • profesorul
                        • Apr 2014
                        • 106
                        #116
                        Re: New project
                        Thanks .
                        MARIUS
                        • drschmidt
                          • Jul 2014
                          • 424
                          #117
                          Re: New project
                          The moulds for the rear bulkhead are done...
                          And the first part has turned out quite nicely. Notice the round flat surfaces that will help to seal the motor fedthoughts.
                          • drschmidt
                            • Jul 2014
                            • 424
                            #118
                            Re: New project
                            I've decided to make the watertight main section out of glass fiber, too. Attaching the deck to a plexiglas tube works, I've tried it successfully. But one has to fill the transition with filler and that is a) an annoying work and b) the result is, compared to the exact and sharp lines of the bow and stern, sub standard. So I have prepared the respective CAD files and ordered the milling of the preforms......
                            • drschmidt
                              • Jul 2014
                              • 424
                              #119
                              Re: New project
                              Pretty much like that:
                              • drschmidt
                                • Jul 2014
                                • 424
                                #120
                                Re: New project
                                I thought a bit more about how to make the hull of gpr without losing the advantages of having a tube shaped pressure hull and to minimize the additional volume by the deck. This is how it's going to be. I can minimize the additional volume of the deck by making a trench in the structure that will be free flooding. The trench will also enable the flooding of the sail and it will connect the free flooding stern and bow sections. The photo-etched brass deck will get cuts that help venting the trench. The bridge structures help to ensure that the deck does not bend. The remaining left and right bump of the deck superstructure will be filled e.g. with resin and microballoons. This makes it possible to lay down the glass fiber in an almost perfect circular shape, restoring the full strength of a tube structure.
