All,
content for this post will be the info and links for the 433mhz segment of the seminar.
there is a lot of the background on OpenLRS that i went over in the seminar, so if you are sitting at your chair reading this and wondering "what is OpenLRS ?" here, to whet your appetite is a small intro:
OpenLRS is a new Open Source hardware and software RF stack designed originally to allow for long range FPV flight of r/c model aircraft. originally "invented" by a gentleman from turkey in 2011, it has been embraced by the open source community and currently boasts functionality equal to or better than the best 2.4ghz equipment available today. for the individuals that originally designed it, it has all the benefits of 2.4ghz technology, but gives them un-precedented range of 20km or more.
for us in the r/c submarine community, it has one huge advantage over 2.4ghz equipment. It has no issues penetrating several feet through water.
without any further ado... on to the info i said i would post
1) the website where one can practice for the HAM technicians license:
there is a set of radio buttons and a "take exam" button in the upper left-hand corner. keep taking the test until you get at least 27 right. then, when you feel you are ready, take a look here]http://www.arrl.org/find-an-amateur-rad ... am-session[/url]
2)
hobbyking transmitter modules and receivers.
RX]http://www.hobbyking.com/hobbyking/stor ... eiver.html[/url]
futaba TX module]http://www.hobbyking.com/hobbyking/stor ... eiver.html[/url]
JR/turnigy TX module]http://www.hobbyking.com/hobbyking/stor ... ible_.html[/url]
please note that the TX modules i list are the 100mw versions. there is no reason to buy the more expensive 1watt versions, i am currently running my subs using the "6mw" rf output setting.
if you do not currently own a transmitter that has a modular rf deck, and you want to try out 433, hobbyking sells a fantastic 9 (really channel computerized transmitter that uses the JR/turnigy module listed above, for a really decent price:
http://www.hobbyking.com/hobbyking/stor ... dule_.html
3)
in addition to the hardware, there is the need for software updates. the hobbyking stuff comes with the bare minimum software, and even they state that the current situation is kind of a throw-back to the good-old heathkit days. you can use the TX and RX as they come, but if you run your stuff around another 433mhz user, your systems will bind to each other's receivers.
so, the latest and greatest software to update the TX and RX with is called "OpenLRSng" and here is the wiki site]https://github.com/openLRSng/openLRSng/wiki[/url]
4)
it kind of explains what needs to go on, but most import is a little dongle you will need to actually connect the circuit boards to your computer, to do the update]https://www.sparkfun.com/products/9873[/url]
in addition to the board, you will need a usb cable to connect the board to your pc. (the type of cable depends on what type of usb connector your pc has)
finally, the easiest solution is to use a plug-in for the Chrome web browser]https://chrome.google.com/webstore/deta ... jnkl?hl=en[/url]
you will then have to download and install the appropriate usb drivers for the ftdi board]http://www.ftdichip.com/FTDrivers.htm[/url]
please note, that on my windows 8.1 tablet, the drivers had to be updated to a version newer than those downloaded from that site, before the configurator would actually show the appropriate comm port for my ftdi board.
finally, 3 youtube videos that clarify the entire "update the firmware" portion of this heathkit type of endeavor.
part 1]http://www.youtube.com/watch?v=1sYzYIjzLMQ[/url]
part 2]https://www.youtube.com/watch?v=Ilmd4FqGzRw[/url]
part 3]https://www.youtube.com/watch?v=CRvkQl1LeR8[/url]
one last thing... for those of you who didn't make it to the regatta, a rather pointless video of my Delta, in its first real water test using the 433mhz setup.
For those of you who made it to the regatta, the Delta ran the entire 3 days using the 433mhz setup with either my tablet based transmitter, or the same module plugged into my futaba 9cap.
*copy and paste those youtube video URLs here, and you can download the video so you can keep it handy on your local hard-drive]http://keepvid.com/[/url]
for those who want to get there feet wet with this amazing new technology, i hope this is enough to get you started. of course if there are any questions, just ask.
2)
 channel computerized transmitter that uses the JR/turnigy module listed above, for a really decent price:http://www.hobbyking.com/hobbyking/stor ... dule_.html
3)
4)
 [/url]
[/url]
 [/url]
[/url]
