Re: Scale Ship Oscar 2
Thanks for your help. I am using blue foam and all three subs that I have act the same way.
It also blew the hose loose from the schrader valve. I had some extra pieces of hose so I made the repairs that evening. All I had to do was take out the copper vessal, replace the hose , reapply the silicone to the attachment bolts and around the fill valve, insert and bolt it back up then reach up thru the large ballast flood holes with a pair of needle nose pliars and insert the schrader back into place and tighten it down.
The new props measure 54mm in dia., an increase of 1mm, which is fine with me.
Another thing I learned was , just like the Titanic found out, clear water next to a iceberg or a patch of weeds does not mean safe passage. Here you can see a NO FEAR OSCAR snarled and snagged in weeds.
