Re: Scale Ship Oscar 2
As a practical matter I drilled these two small holes in the hull to service the set screws on the u-joint coupler and the wheel collar that holds the thrust bearings.
You can see them here along with the final configuration of the linkages.
Sorry for the sideways picture but I had to shoehorn the camera down into the open hull to get it.
Driveshafts in place.
Then I drilled 10 1/8" dia. holes down the centerline of the upper hull to help vent the hull. I also chamfered them from underneath.
Because of the design of the wooden stand I can lay the submarine over on its side for various purposes.
You can see here the mismatch of the indexing seams at the rear when you even up the top of the hull halves. Later this will have to be filled.
