Scratch type 17 project begins
    #151
    Chuck Yeager. The best pilot
    Chuck Yeager. The best pilot I ever saw. I got to meet him and spend some time with him. Great guy.
      #152
      Mylo -
      Here's an assigment
      Mylo -
      Here's an assigment for you to do during your 6 months of Saskatchewan winter]http://www.subcommittee.com/forum/icon_cool.gif[/img]
      Edited By TMSmalley on 1128961648
      • koeze
        • May 2003
        • 204
        #153
        Steve.
        Man what an awsome build.
        Steve.
        Man what an awsome build. Hull looks very clean. Thanks for these valuable lessons. I think I'll copy the #### out of this thread and make it somthing of a manual for me.
        Incredible the amount of detail you got into this boat and the time you did it in. Amazing.
        Now I'm off to my hobby attick and start cleaning it up a bit to start work on my own Walrus again.
        Read the entire thread in one time.
        Man....
        Erik Jan
          #154
          Erik,
          Thanks so much. This is
          Erik,
          Thanks so much. This is why I do it this way so guys like you can get to building a model of your dreams. Kits are great. But scratch building is true creation. Can't wait to see what you do.
          Grtz!
          Tim,
          Although the movie is inaccurate to say the lease I love it anyway as it truly captures the feeling of the period when cowboys road the clouds.
          Hey Ridley. What's next?
            #155
            Well you guys I've had
            Well you guys I've had to work for the last few days so no progress on my build. However I'm back tomorrow.
            I will also start making beta kits up next week for those that want one. I did get all my materials this week. Let me know if you do.
            I'm sure there are many of you waiting to see the finished product before making a decision. That's fine by me. I should finish by next weekend I hope.
              #156
              Here's a lot of basic
              Here's a lot of basic stuff. I first made up a stern bulk head (templates will be on the CD that comes with the kit) that supports the prop shaft bearing and two guides for the golden rod to exit to the WTC attachment points.
              I also placed a shaft bearing in aft of course. The bulk head gets cut out, holes drilled and some brass tubing as guides that are glued in with epoxy and micro balloons.
              Then I placed the bulkhead in place and put the shaft through until it comes through the hole drilled for the prop shaft bearing in the bulk head. Placed the bearing over the shaft and pushed into place. Then I adjusted the bulkhead and alignment of everything until satisfied and glues everything in place with epoxy and micro balloon mix.
              Next I made up the index parts for the the hatch. All this consisted of was 040 ABS sheet but you can do this anyway you like. Right Big Dave? Dave has is own way of indexing his hatches that I've been too lazy to try. Maybe he will enlighten us here. Huh Dave?
              Next again using the templates from the formers used to make the hull master I made up two bulkheads or mounts for the WTC from the thick PVC sheet I get from the LHS.
              The hatch itself is held down by screws as it the sail. You can see in the pictures that the screws enter the bottom side of the deck and screw into two PVC plates I made up and glued into the sail. I also used a dremel to bore out the deck and holes in the sail.
              Next I'll get cosmic and start getting her ready for paint and while that dries I'll start the scope, snorkel, antennas and the radar hoop.
                #157
                the rest.
                http://www.sneill.com/type17wtc_in.jpg
                http://www.sneill.com/type17/sail_mount1.jpg
                http://www.sneill.com/type17/hatch_screws.jpg
                http://www.sneill.com/type17/wtc_in.jpg
                http://www.sneill.com/type17/all_together.jpg
                Edited By U8
                the rest.
                Edited By U812 on 1129704097
                  #158
                  Well I made a prop
                  Well I made a prop today. Still need to add the dunch cap or spinner to it.
                  Also every thing nechanical is done and work well. I could run her if I wanted to but I'm moving on to paint and details next.
                    #159
                    Some more progress today. I'm
                    Some more progress today. I'm still going to make all the small parts first before I start preening the hull for paint.
                    I started on an interior which I have placed inside the sail for a look. Made the snorkel and scope. Antenna is in. They all retract manually.
                    I still have to add the railings, and the retractable stabilizer on the bow. Most od this stuff is fun and easy. I hope to paint her this weekend. My favorite part and yes it gets weather and rusted!
                    • mylo
                      • 723
                      #160
                      Steve,
                      Do you use roller
                      Steve,
                      Do you use roller bearings for the prop shaft ? I've got a 1/10 scale R/C 4x4 that has many different roller bearings used for the driveline of a small size, which got me thinking that they would work very well for prop shafts and the like. The concern, of course, being corrosion but I suspect if they were given a light coating of grease and blown dry with pressurized air after use, their life could be prolonged. They are actually partly sealed to prevent dirt from getting in there.
                      Thoughts ?
                      Myles
                      P.S. Really looking forward to the paint job on the XVII.
                        • 1325
                        #161
                        looking really good Steve...I have
                        looking really good Steve...I have to agree with you...the best, most fun part is still coming up- weathering!!!!
                        oh, yeah, then putting it in the water and running it too
                          #162
                          Sam,
                          Thanks a whole bunch!
                          Sam,
                          • typ 202
                            • 21
                            #163
                            Steve,
                            What is that plastic sheet
                            Steve,
                            What is that plastic sheet that you show on the previous page? The label says PVC-foam. Is it flat sheet or is it foam? Stiff, flexible, moldable, etc?
                            Mike
                              #164
                              Flat sheet. A bit flexible.
                              Flat sheet. A bit flexible. Easy to sand. Easy to cut. A lot like plastic balsa wood. I used it to shape the appendages and make the masters. It can be used straight. Great for making one off parts two.
                              Can you think of the uses? Makes great WTC supports too. Most local hobby stores carry it.
                                #165
                                All painted. All parts are
                                All painted. All parts are on that I hand made. Now to weather it tomorrow and she's done.
