New project aquesition
    Re: New project aquesition
    I am using two Polks ESC's I had. Same length and width, but maybe twice the hight.
    Still quite small.
    • steveneill
      • Jul 2009
      • 716
      BD!!! Why doesn't this surprise me?!! Love it!
      www.steveneillsgarage.com
        Thanks Steve.
        I wish I could airbrush like you to finish it off.
        I bet you could really do it justice if you have not built one already. BD.
          I have not had much time this week to work on the project.
          I have figured out how I will connect the two cylinders together and run the power.
          Also where the battery will go.
          So stay tuned. News at eleven! BD.
            OK here are some more photos.
            Nothing is hooked up and just pushed on for the photos.
            Just to give an idea of what it looks like.
            • steveneill
              • Jul 2009
              • 716
              Pretty! Cool! Love it.
              • crazy ivan
                • 659
                ..... I just had to go with the more powerful PPJ's.
                I had never used them in a model before and I need approval from Ivan.
                Well he has not sent his Cossacks after me anyways. :lol
                I don't usually log in to view the active posts, but I needed to download the SCR. Well now that I see what goes on behind the closed curtain, I'll have to log in more often. I'll be watching.
                BTW, I thought you used a PPJ in your Seaview??
                sigpic
                -George Protchenko
                  I stand corrected.
                  I did use a PPJ in my Seaview, the production version used BTP's.
                  I forgot.
                  Just finished the cylinder assembly for the Raider.
                  Everything fits and works. O happy day!
                  It took a while to program the radio for all the mixing.
                  It is set up like an airplane on mode 4.
                  Rudder and elevator on the right stick and throttle and ailerons on the left.
                  Now on to installing the cylinder and battery in the Raider.
                  Right now I am thinking of using a hard case Lipo and sealing off where the wires come out with silicone.
                  Basically making it a sealed battery. A 4000MA 7.4V will fit between the two tubes and will connect to the two input thumb nuts on the front of each tube. One plus one minus.
                  This is my next plan of attack. Well back to work. BD.
                  • steveneill
                    • Jul 2009
                    • 716
                    It's a beauty!
                      Someone needs to build a viper of equal size. Big Dave cannot be allowed to dominate the pond through force and fear!
                      • steveneill
                        • Jul 2009
                        • 716
                        Hmmm...
                          The cylinder assembly is mounted.
                          I used part of the hull bracing to hold it in.
                          Using the power connections for the front attachment points.
                          If all goes well I will be able to connect the power right through the front intakes.
                          My plan is to try and duct the water when in reverse out the intakes for some reverse thrust maybe.
                          Not that I need reverse but I just feel like trying.
                          BTW Vipers suck!
                          I will blow all Colonial forces out of the sky! Err, water!
                          By Your Command!
                          • Rick Teskey
                            • 217
                            #28
                            What, you don't like the Colonial lawn dart?
                            You frakin toaster lover!
                              Shouldn't the title be New Project Aquasition? aqua-sition? get it? Oh, I crack myself up.......why isn't anyone laughing?
                                • 947
                                #30
                                *snicker*
