1/72 Nautilus
  • Rogue Sub
    • 1724
    #31
    Re: 1/72 Nautilus
    Here is a bit of excitement The lower half of the 571 is complete.
      #32
      Re: 1/72 Nautilus
      sure is a nice way to produce a new hull in a hurry.
      is the result smooth enough or do you need a bit of sanding still ?
      • Rogue Sub
        • 1724
        #33
        Re: 1/72 Nautilus
        Yes very slightly
        There is a final pass that only takes off thousands of an inch and gets it very close
        Here is a shot of the top starting. The bottom is complete.
        Kevin
        • Rogue Sub
          • 1724
          #34
          Re: 1/72 Nautilus
          Here are few more shots of the top coming together.
          • Rogue Sub
            • 1724
            #35
            Re: 1/72 Nautilus
            Had to step away from this for a few days for family business but I am back home now and have lots of pics to share!
            • Rogue Sub
              • 1724
              #36
              Re: 1/72 Nautilus
              Here is a shot of the propeller support fins as they came out. The plan is to cast these parts as part of the hull and as one piece with the bearings in place so that the end user wont have to knock their brains in trying to get everything lined up proper.
              Kevin
              • Rogue Sub
                • 1724
                #37
                Re: 1/72 Nautilus
                There have been a requests to have the kit supplied with the polar ice sail so one is getting put together. In the end you will just request which sail you want with the kit or both.
                • Rogue Sub
                  • 1724
                  #38
                  Re: 1/72 Nautilus
                  Now the polar sail is complete and this conclude all of the cnc work with this boat. Pics of the props will be up soon.
                  • Rogue Sub
                    • 1724
                    #39
                    Re: 1/72 Nautilus
                    There has been some questions as to the actual size of the boat due to the large size of the CNC. Here is a pics next to a ruler and a shot of both sails.
                    • Rogue Sub
                      • 1724
                      #40
                      Re: 1/72 Nautilus
                      Here is a shot of the props in process. The blades still require shaping.
                      • Rogue Sub
                        • 1724
                        #41
                        Re: 1/72 Nautilus
                        Propellers are coming together nicely now
                        • Rogue Sub
                          • 1724
                          #42
                          Re: 1/72 Nautilus
                          Here is a shot of the propeller support fin with prop mounted on a 1/8" Stainless shaft. Everything fit first time with zero modifications.
                          • timothy guest
                            • 25
                            #43
                            Re: 1/72 Nautilus
                            Looking good. I predict this will be a hit with all the first generation nuc boat fans, including myself. Looks like I'll just have to get one of these.
                            • Rogue Sub
                              • 1724
                              #44
                              Re: 1/72 Nautilus
                              Perhaps you will make it to Groton for the fun run and you can join the group picture we are planning at the Nautilus.
                              Kevin
                                Re: 1/72 Nautilus
                                Any new updates Kevin? BD.
