1/72nd scale alfa class ssn
    • 1479
    Re: 1/72nd scale alfa class ssn
    Take a look at this link:
    http://www.subpirates.com/showthread.ph ... ild-Thread
    Just register and go read. It is very long but details all of the molding techniques and products you will need to successfully mold your boat with ease. If you have any questions....just ask!
    • the dark knight
      • Feb 2010
      • 164
      thank you so much Matt!
      • the dark knight
        • Feb 2010
        • 164
        more progress.
        applied a coat of resin.....
        then i sanded said resin down. wow this stuff is tough...
        so i dug out my trusty bondo to finish smoothing out the plug
          • 1479
          It helps a lot if you add thixotropic silica to your resin mix. It sands a LOT easier....It is also known as cab-o-sil....
          • the dark knight
            • Feb 2010
            • 164
            gotcha Matt! ill keep that in mind. more work done today..... more to come soon
            • the dark knight
              • Feb 2010
              • 164
              well, have to say, the bondo is going much faster than before. i might get to mold this this weekend i hope!
              and here is where it sits now. its bed time boys and girls! good news is we had a bad ice and snow storm roll through. so i have all day to work on this tomorrow!
              • the dark knight
                • Feb 2010
                • 164
                more bondo work today. here is where it sits now.
                i feel confident that it is now smooth. however..... i have a question for you guys. should i primer the hull, wetsand, primer, wetsand till its smooth and then mold it?
                • bill rogers
                  • Sep 2003
                  • 90
                  Yes, but try alternating two different colors of primer. Then sand down only to the previous color of primer to avoid too much sanding in that area. Keep the photos coming.
                  • the dark knight
                    • Feb 2010
                    • 164
                    gotcha! thanks bill! i have grey here and dark grey rustoleum primers. photos soon!
                    • the dark knight
                      • Feb 2010
                      • 164
                      found some small spots that i need to patch. not too bad! im happy with the progress so far.
                      edit;
                      filled in the low spots. re-priming her now
                      • the dark knight
                        • Feb 2010
                        • 164
                        ok. back to this project! i was sidetracked last week, a friend of mine asked me to repair a broken stormtrooper helmet that he owns that was cast from the screen used helmets. long story short, i replaced the ears, fixed some cracks and repainted the whole helmet. hope he likes it.
                        updates soon!
                        • greyakula52
                          • May 2005
                          • 98
                          ahoy Captain!
                          Lookin' Good!
                          Captain Andre
                          • the dark knight
                            • Feb 2010
                            • 164
                            #28
                            so! i went to the hobby store today (mark twain hobby in st. charles mo) and picked up some more apoxie sculpt.
                            ive used this stuff before on a vader reveal helmet i built for a friend. it has a 3 hour work time, and untill that point, you can smooth it like clay and detail it. once it sets its rock hard and stronger than the fiberglass on the reveal helmet, and supposedly water proof. in the morning i plan on testing sculpting a dive plane out of it. time will tell!
                            • the dark knight
                              • Feb 2010
                              • 164
                              #29
                              well, im happy to report that after lots of tests, the apoxie sculpt seems like a good canidate for this project! it sculpts like clay, and after it cures is like fiberglass as far as hardness goes.
                              here is the rough shape of the lower rudder
                              here is where the rudder sits now. its been shaped, and i filled the low spots with more apoxie sculpt. waiting for that to cure now.
                              so thats where i sit now! the upper rudder is curing as we speak! updates tomorrow i hope!
                              • the dark knight
                                • Feb 2010
                                • 164
                                #30
                                more progress on the rudders! the upper is roughly shaped, the lower is almost done. primered the hull again, and disaster struck.... the primer reacted.... i know why. in my rush i forgot to prep the surface again. oh well, i can fix it.
