1/72nd scale alfa class ssn
  • the dark knight
    • Feb 2010
    • 164
    #121
    Re: 1/72nd scale alfa class ssn
    Thanks Matt! I downloaded and read the instructions. I think I will steal your set up for the dive planes and rudder linkages in the tail as well! Thursday I am going over to my parents place in St. Louis and hit up some of my favorite hobby shops for a few small things to finish this boat.
    • the dark knight
      • Feb 2010
      • 164
      #122
      More work on Alfa today. I resprayed the black on the upper rear of the hull to fix runs I had from spraying the red. I then painted the rest of the water line and clear coated it. I also stuck a 1/8th inch brass rod in the hole I cast in for the future prop shaft. The reason? So I can have the prop sit on the rear of the boat, and give me some encouragement!
      Since it will be warm here today and tomorrow I am trying to get as much painting done as I can before it gets cold again.
      • the dark knight
        • Feb 2010
        • 164
        #123
        Okay, so I should have this bad boy done very soon! This last weekend I purchased all the hardware needed to finish Alfa mechanically. I have oilite bearings on order, should be here in a few days. I got a Dumas 3/16th stainless steel drive shaft I will install once the bearings arrive. Then hook the linkages up for the dive planes and rudders. Then all I should need are a few electronic parts and she will be in the water.
        • jeffrey j
          • Apr 2004
          • 398
          #124
          Wow Jon,
          I can't get over the fact you scratch built this, i seen earlier pics. when you started, but man, this sub is really coming together. Very nice work. Your getting me motivated. thanks Jeff Jones
          • the dark knight
            • Feb 2010
            • 164
            #125
            Thanks Jeff! I look forward to seeing your Sturgeon finished.
