1/72nd scale alfa class ssn
  • the dark knight
    • Feb 2010
    • 164
    #106
    Re: 1/72nd scale alfa class ssn
    I have some Billet Aluminum left over from my racing days, and was thinking of making the propeller out of this. I could buy a prop, but all the ones I see are brass, and Alfa had a Titanium propeller. I would like for my Alfa to have a silver prop that will not require paint to make it the right color (or close to the right color). Could Billet Aluminum be used to make a propeller, or is there someone that makes Alfa props in a white metal about 2 inches in diameter?
    • the dark knight
      • Feb 2010
      • 164
      #107
      Not much progress, but it is some. I scored a Futuba 4YF 75mhz radio for 85 bucks!
      • the dark knight
        • Feb 2010
        • 164
        #108
        Lookie what showed up today!!!!
        Tested the set out to make sure I did not get ripped off on e-bay. Everything works! It is 75mhz set to channel 84. We can scratch the radio set off the list!
        Also have ordered a stainless steel prop from the prop-shop. Pricey, but hopefully it will look good.
          • 2349
          #109
          Sa-weeet radio! We'll done.
            • 1479
            #110
            Well done, Jon! That will work well for you.
            • the dark knight
              • Feb 2010
              • 164
              #111
              Thanks guys! I have been watching ebay like a hawk, especially since this particular radio is out of stock and is currently back ordered most places I have looked. I might get a few more if they pop up to use on future projects.
              • the dark knight
                • Feb 2010
                • 164
                #112
                Started the red below the waterline. Looks like this is all the more I will get done paint wise for a while. It is starting to rain, and is supposed to snow tomorrow, and without a place to paint inside, I am at the mercy of the weather. Here is where she sits-
                And on that bombshell, I will now shift back to the Delta IV.
                • the dark knight
                  • Feb 2010
                  • 164
                  #113
                  Christmas came early today. My propeller from the Prop Shop showed up today.
                  Stainless steel. Cost me a bit more, but I am happy with the result. I want to change a few minor things, mostly the hub, so it matches this one a bit more-
                  Will this be possible to do? I suppose I can solder the details on? Any ideas anyone? or should I leave it be?
                    • 1479
                    #114
                    Jon,
                    Call it a day with the prop. Soldering will, forever, tarnish the surface.
                    • the dark knight
                      • Feb 2010
                      • 164
                      #115
                      That is a good point Matt. I did not even think of that. Could I make the tip of the hub out of say, aluminum, cut the hub so it is flat and bolt them together? or would that most likely not be as strong? I might just write it off at this point. I am so close to finished, and I keep making more work for myself.
                      As for the prop shaft, I have seen some use bearings on the prop shaft, I have seen other's make stuffing boxes with Vaseline acting as a lubricant. What would you guys recommend?
                        • 1479
                        #116
                        I use 3/16" SS shafting with oilte bearings exclusively. No grease needed and they last for years.
                        • the dark knight
                          • Feb 2010
                          • 164
                          #117
                          Thanks Matt! Would you recommend the 3/16" id X 5/16"od X 7/16 od flange x 3/16"long bearing since it has a a flange to act as a thrust bearing?
                            As an alternative, I like to use flanged Rulon J bearings. Never need any oiling, extremely friction-free. They can be found at McMaster-Carr in various sizes. Here's an example:
                            McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.
                            • the dark knight
                              • Feb 2010
                              • 164
                              #119
                              Thanks Jeff! Looks like I have a few options. For some reason, I was thinking these bearings were very pricey. However, that does not seem to be the case! Now I wonder what Bearings I was looking at that were so pricey?
                                • 1479
                                #120
                                Jon,
                                Take a look at the downloadable PERMIT instructions on the Precision Pattern website. It shows a typical installation. I use two types of oilite bearings; radial and thrust. You will see them both installed in the instructions.
