First Alfa run of the compressor based 5 ft Alfa
This pond is huge and
This pond is huge and is in a very nice park here in Ocala .The banks are high on one side but total access and great shaded walkways and fasilities just a bit merqy now but later it does clear up a bit.The nice thing about this pond is the high banks that give you a great prospective of your sub.
There is a good place to lanch subs as well,some day we should check it out
In the past few days
In the past few days I have added a auxillary 12 volt 3 amp hour battery located in the rear oft he ballast tank ahead of where the lead ballast used to be ,I needed to operate the solinoids on a seperate power supply becuase the switching was knawking the ESC off line somhow I could not find a cure it was intermittent and sometimes I had to reset the radio as well ,not fun.
So I cut open the belley of the sub at the right place for this battery to fit into at an angel due to the airbanks just above it and by a millimiters it fit! So now by remote control on the 9th chanel the auxillary battery can be engaged to run the main drive and the rest of the sub for a chort time just to get her back to port and to run the solinoids on a seperate powersorce ,sure beats the 3 lbs of lead that where in its place.Also a more powerfull pump was aded for the 3 main masts.
A special relay switches the batteries from main to aux or back again,and the same servo with microswitches oprates the nave lights.
The bat waighs the same by just luck I had the right size and if needed adjustments to ballance can be made.Always be sure that the battery is not too big to be counterballanced.
Amur Shipyard Dave
