Julian,
As I had similar problems
I took a look at my Engel Lafayette ballast motor for polarity markings. I noticed a small black circle along side one of the motor lead connectors that has a + sign molded into it. It is small, but it is there!
Julian,
As I had similar problems with my Lafayette at the beginning, I found that I had wired the pump motor in reverse. Engel does not mark the motor polarity..............."
You can write me direct- michael_42_kf@msn.com
Good luck-Mike
Can one of the Administrators move this to R/C?
Good luck-Mike
