Engel dive systems - How to instal B.T.S. 1584
  • lobo
    • Jan 2006
    • 48
    Julian,
    As I had similar problems
    Julian,
    As I had similar problems with my Lafayette at the beginning, I found that I had wired the pump motor in reverse. Engel does not mark the motor polarity..............."
    You can write me direct- michael_42_kf@msn.com
    Good luck-Mike
    Can one of the Administrators move this to R/C?
    I took a look at my Engel Lafayette ballast motor for polarity markings. I noticed a small black circle along side one of the motor lead connectors that has a + sign molded into it. It is small, but it is there!
    • mac.one
      • Dec 2005
      • 25
      Hi All
      Just wired in
      Hi All
      Just wired in the norbet bruggen bts (same wiring dia.) as engle switch and guess what it works (thank god) lot of sleepless nights over this one. Engle switch must have been faulty.
      Only problem now is the red led is flashing which i believe signifies under voltage. Checked voltage on batt. thats ok. According to manual the under voltage regulator is variable but it does'nt say how to adjust anyone help again please.
      Regards Julian.
      Hi Just reposted the above again hoping someone can help further, E-mailed norbet brugen as yet no reply.
      Thanks in Advance Julian.
      • subtech
        • Oct 2004
        • 26
        Hi Julian,
        Regarding the BTS switch
        [color=#000000]Hi Julian,
        Regarding the BTS switch and the flashing red LED, here's what the various flashing sequences mean]
        • mac.one
          • Dec 2005
          • 25
          Hi Dave
          Many thanks for
          Hi Dave
          Many thanks for the quick response will try your advice tommorrow and let you know how i get on.
          Cheers Julian.
          • mac.one
            • Dec 2005
            • 25
            Hi Dave
            Advice worked a
            Hi Dave
            Advice worked a treat, switch now operating as it should. Many thanks and thanks to all who contributed.
            Cheers Julian.
