Dave Welch's Type 7 WTC build
    #31
    Here's a better video. Can't
    Here's a better video. Can't wait to get this boat in the open water as my pool just doesn't cut the mustard.
    This ends the thread for me but those of you building Dave's wonderful WTC for this boat are welcome to post your progress here.
    http://sneill.com/uboat/type7_2.wmv
      Hay Steve,
      I finally got
      Hay Steve,
      I finally got a chance to finish my V11c detailing. I know, I know, it has a anti-foul red bottom. So sue me! I like to believe some were made that way. You never know! Dave.
      Edited By Bigdave on 1116379576
        Very nicely done, Dave!
        .....as for
        .....as for the red, just think "pre-war boat" and dare'em to argue!
          #34
          That's right Jeff. Now you
          That's right Jeff. Now you got it. Looks great that way! I like it!
          • tabledancer
            • Feb 2005
            • 573
            #35
            Dave,
            Your boat really looks good,I
            Dave,
            Your boat really looks good,I like the netcutter and the red. It makes the boat offically "early",if some people bitch tell them to bad it`s my boat.By the way is this a static boat or R/C.
            Keep on keepin on
            T.D.
              Thanks for all the nice
              Thanks for all the nice comments guys This is the R/C version. It has my WTC with bow and stern planes, motor, rudder and RCABS ballast system. It uses my new single bladder system. Thanks Jeff, I was hoping for a Pre-war blessing on the boat. I just love that red. Dave.
              Edited By Bigdave on 1116433319
              • jdlockh
                • 48
                #37
                Dave, the sub looks great.
                Dave, the sub looks great. I'm going to be using a single bladder as well, can I get some pictures of the your setup?
                James
                  #38
                  Here's another test I did
                  Here's another test I did tonight. Unfortunately the rear dive plane wheel collar disconnected during the run which gave me pitch problems. It also shows you why you want to use both planes in this boat.
                  I had no help one more time so it's point and shoot. But you can tilt and pan with this system. Next time you will see this.
                  You hear the actual sounds of the boat this time as the tank does pic up the under water sounds.
                  Enjoy.
                  type 7 under water video test
                  Edited By U812 on 1118387810
                  • kapleun val
                    • Jun 2005
                    • 22
                    #39
                    i like what you have
                    i like what you have done, im currently doing the VIIC revell conversion, just eanted to know with this WTC did you have to cut your sub at all? or was it slim enough to squeeze in by taking the decking off? if you have any tips or anything you think might help me out i would be gratefull for an email.
                    many thanks
                    Paul
                    • jdlockh
                      • 48
                      #40
                      Paul, it is small enough
                      Paul, it is small enough to fit in the deck opening.
                      james
                      • kapleun val
                        • Jun 2005
                        • 22
                        #41
                        thanks james, i may have
                        thanks james, i may have to look into this one if my attempts fail.
                        Does anyone know the conning tower should be air tight or free flooding? what do you recommend and why? im a beginner so any help is appreciated!
                        thanks
                        paul
                        • tabledancer
                          • Feb 2005
                          • 573
                          #42
                          Paul,
                          I just finished the hull
                          Paul,
                          I just finished the hull work on my boat,I opened everything up on my hull including the lower flood grates fore and aft,the only other modifations that I made to the hull were adding brass bushings to the pivot points of the dive planes and rudders as Dave suggested on his kit CD.I also am using a WarHammer c/t kit which is very nice and the Model Brass Deck kit for the hull and flood grate details.Also I had to enlarge to the openings in the vertical frames inside the the hull to support the WTC,just slightly though.If you have any problems let me know,we can struggle through together.
                          TD
                            #43
                            Kapleun Val,
                            You need to read
                            Kapleun Val,
                            You need to read the entire thread. It answer most of your questions. You do not need to cut the hull at all. Looks bad and there enough room to slip the WTC in through the deck.
                            Here's the sequence from Dave's CD. These are small pictures but you'll get the idea. The CD if you buy the WTC kit has much larger pictures.
                            PS
                            Hope this is ok with you Dave. Many don't believe it's possible and this should end that debate. For good!
                            Edited By U812 on 1118949854
                              Steve,
                              Not a problem my
                              Steve,
                              Not a problem my friend! Thanks, BD.
                                #45
                                Why reinvent the wheel? Your
                                Why reinvent the wheel? Your wheel works great Dave. And as a result the boat holds it's very scale looks. That's what I like best for one about your design.
