1/72 598 SSBN scratch build
  • 598602G
    • Mar 2018
    • 71
    OK guys first time on here. Tim Cobb here. Been working on plugs/molds for a 1/72 598 SSBN. I was on the Abraham Lincoln SSBN 602G. Sail is done except for scribe detail. Appendage molds done. Resin cast some parts. Hull plug just have to glass it and scribe detail. Turtle deck have to scribe details in it. Should have molds done in less then a month. Almost done with plugs for a 1/72 Thresher. After those are done my next builds will be a 1/72 Victor III, 1/72 Yankee II and a 1/72 Charlie II.
    • 1479
    Beautiful work, Tim! Since this is your first time here and many may not be aware of your excellent work, would you mind discussing the process you use to create your patterns?
    • 598602G
      • Mar 2018
      • 71
      1/72 Abraham Lincoln SSBN 602 build
      I make the hull plugs out of styro foam. Use 2lb+ foam about 3" thick. Sail and appendages I shape out of hard balsa. Glass over the all balsa parts. I use RTV silicone mold stuff I get off ebay. I figured out how to make the appendage molds from one mold instead of split molds. I will post pics of those molds tomorrow as it got too dark in my work area and I normally only work in sunlight for best results. I make my own scribe tools using old needle files. Molds I made in past are 1/72 Alfa, 1/72 Golf II, 1/72 Charlie I and the 1/96 Delta III. I think Bob Martin has some of those kits for sale. Dob Spielberger of Loyalhanna owns the molds to those. Here are some pics of my enlarged Yankee II vector drawings. Behemoth at 72.5" long.
      • 598602G
        • Mar 2018
        • 71
        Pics of the boats I made from my molds.
          • 1479
          Ohhhhh.....I like that Delta! What scale is she?
          • 598602G
            • Mar 2018
            • 71
            That is 1/96. My favorite is either the Charlie I or the Golf II.
              • 340
              Some more pictures of Tim's work.
                • 1325
                I always wanted to build a Golf. So Type XXI-ish, yet so ugly...
                beautiful models.
                • 598602G
                  • Mar 2018
                  • 71
                  Bob pics look great. Makes me sick I sold the boats. Trying to get Don to make me those boats from the molds. I still think the Golf II is my favorite. I will post some more pics today of the 598 and the Thresher plugs.
                  • jure george
                    • 360
                    Hi
                    598602G or Tim. Your sub`s detail is some of the Best I have ever seen. It will be a good seller for Don when he is able to start making them since you sold him your molds.
                    George
                    • lhdockyard1
                      • Dec 2011
                      • 288
                      Tim
                      Will make those hulls for you as quickly as I can. Got a couple ahead of you to finish off and then I will get started. Finally got my kidney stones blasted last week so I should be able to spend more time in the shop. Too bad I have to work for a living or I would be in the fiberglass shop 20 hours a day cranking stuff out. I keep telling my wife to buy the winning lottery tickets so I can retire, but that hasn't happened yet.
                      Don
                      • 598602G
                        • Mar 2018
                        • 71
                        Don thanks. Hope your health gets better. My breathing has gotten worse so I am really going to start getting this house sold and move to Dallas. Have to order another gallon of resin so I can finish up 598
                        • 598602G
                          • Mar 2018
                          • 71
                          Pics of the sail. Top of the sail I am going to resin cast that as much easier to manufacture. Forgot about the access door into the sail so will scribe that tomorrow then it is ready for molding. Click image for larger version
ID:	130588Click image for larger version
ID:	130589Click image for larger version
                          • tommydeen
                            • 327
                            Your delta is nice!
                            • 598602G
                              • Mar 2018
                              • 71
                              Thanks. I went blind doing all the flood holes. Decided I will be making the 1/96 Yankee II and I just got some super detailed plans for a Alfa. That one I think I will redo that in 1/48.
