US MBT Vents
  • peter w
    • Aug 2004
    • 40
    US MBT Vents
    Hello all,
    If you had to describe the colour of US MBT vents what would they be?
    USS Seawolf SSN-21.
    Peter.
  • boss subfixer
    • Aug 2004
    • 656
    The same as the rest
    The same as the rest of the bottom of the boat, black. Or red if your doing an older boat with the two tone paint job.
    • bharris
      • Jun 2004
      • 103
      Don,
      You are upside down. Floods
      Don,
      You are upside down. Floods on the bottom, vents on the top.
      They are stainles steel, no paint unless some topside gang gorilla painted them when the inport vent covers were off.
      Bob.
      • ricknelson
        • Dec 2006
        • 186
        You're talking about nuc vents
        You're talking about nuc vents Bob. Fleetboat vent systems were under the deck and were painted black along with everything else under there.
        • boss subfixer
          • Aug 2004
          • 656
          Sorry Bob (and Peter)your right.
          Sorry Bob (and Peter)your right. I'm upside down. They don't get painted.
          • bharris
            • Jun 2004
            • 103
            Rick,
            Last time I looked "USS
            Rick,
            Last time I looked "USS Seawolf SSN 21" was a US nuke and not a fleetboat. But I could be wrong due to advancing age.
            It appears peter is refering to the USS Seawolf for color of the MBT vents.
            Peter, we normally use etched stainless steel inserts for the vents but any color duplicating stainless will do. You can also use stainless washers with the bolt pattern lightly punched into them.
            Bob.
            • peter w
              • Aug 2004
              • 40
              Thanks guys,
              I am building the
              Thanks guys,
              I am building the Trumpeter Seawolf and am using (the British size) 8ba washers but they are not easy to get in stainless, I do however have lots in brass. I have a tool that rebates the hull slightly so that I can get them in flush, I have tried various different silvers but can't make my mind up which looks best.
              Thanks again,
              Peter.
              • hakkikt
                • 246
                Could you used nickel-plated washers?
                Could you used nickel-plated washers? The metal colour is different from SS, but at least it is silvery metal. Might rust with time though.
                  Metric size but near as
                  Metric size but near as dammit-
                  http://www.microfasteners.com/catalog/p ... METFWM.cfm
