Just when you thought it was safe to go back in the water!
    Thanks Frank. http://www.subcommittee.com/forum/icon_biggrin.gif
    I have
    Thanks Frank.
    I have the WaterSlider info.
    Length=20"
    Max Dia=3.25"
    Weight=3LB 5OZ
    As she sits now I feel she has way to much power.
    The boys at the Groton run could not believe I was saying that, but I need to tone it down and round off her sharp edges so to speak!
    She is a work in progress. BD.
    • Wheelerdealer
      • 315
      #32
      Thanks BD. Just as I
      Thanks BD. Just as I thought, mine a bit larger and double the weight.
        Hi Ramesh,
        Just like in
        Hi Ramesh,
        Just like in cars it comes down to power to weight ratio.
        When I was younger (and smaller) I had a Lotus Europa Twin Cam. It only had 125HP but it only weighed 1500LBS and went like a scared cat. .
        There are other variables I am sure, but the power to weight has to be a big factor. BD.
          There'll be quite an increase
          There'll be quite an increase in wetted area in the Subdog over the waterslider, so that must raise drag quite a bit.
          Norbert Bruggen makes a smaller ballfish, about 16" in length. I think that would make a nice base for a fast sub.
          • Wheelerdealer
            • 315
            #35
            My Subdog video.....
            http://uk.youtube.com/watch?v=x3ax2AfRV7g
            Next up will
            Next up will be to try her with a larger prop and more cells
            • polaris
              • Feb 2008
              • 107
              #36
              Great Stuff Wheeler! http://www.subcommittee.com/forum/icon_eek.gif
              How far into the air will it go at flank speed?
              Looks to be very stable at high speed.
              Stuart
                Great video Ramesh!! http://www.subcommittee.com/forum/icon_cool.gif
                It
                It looks like the Subdog is running good. BD.
                  I was at the controls
                  I was at the controls of the Subdog, whilst Ramesh took the film. It runs as straight as a die, but has a tendency to dive unless adjusted just right, then the bow lifts on a turn, which why the boat comes to the surface now and again. You can just make out my dulcet tones suggesting mixing in a little down elevator in with the rudder control.
