Foam - How does it work?
  • himszy
    • Nov 2004
    • 282
    Hi
    You know the foam you put inside a wet hull, how does it help keep the sub afloat? Also what's it made of?
    Thanks Michael
    Michael-
    the foam everyone always speaks
    Michael-
    the foam everyone always speaks of is the blue or pink insulation foam sheeting that can be found at places like Home Depot or Lowe's. Typically it's a rigid foam, dense, and it doesn't wick up water. It's used inside hulls to aid bouyancy by displacing water, while strategic placement of pieces of this foam can help balance/adjust your model so it sits correctly in the water.
    Hope that helps.
    • chips
      • 497
      Dow styrofoam is blue. Owens-Corning
      Dow styrofoam is blue. Owens-Corning makes the pink stuff.
      Edited By chips on 1104642302
