Magnetic Plane Connectors
    • 2352
    ​Bob is working on a submarine from the movie League of Extraordinary Gentlemen, the Nautilus.
    In the discussion, there was mention of narrow hull (I was not careful in reading) and thought that was why he was not going to put some planes in. That got my mind cranking (lots of clattering and noises to get it started - LOL), but I thought of magnets.
    Here was the Crayon drawing:
Name:	Crayon Drawing of connector.jpg
    Then I went to Fusion360 and drew out my idea.
Name:	Magnetic Plane Connector 00.jpg
    Then printed it to test.
Name:	Magnetic Plane Connector 05.jpg
    And assembled
Name:	Magnetic Plane Connector 01.jpg
Name:	Magnetic Plane Connector 02.jpg
ID:	138043Click image for larger version
Name:	Magnetic Plane Connector 03.jpg
    I like this enough to try it on a boat. The hold is better than I thought, however as I was drawing this out I put in a semi circle lip on the push rod connector, that I think would minimize slippage. In this prototype it is too small to be effective, but I can expand it if needed.
    • 684
    Tom,
    Very interesting! I can see that being quite useful in a small or narrow boat!
      Tom,
      What resin are you using? The DLP resin I use is really fragile and wouldn't take the load. You must be using some pretty tough stuff!?
        • 2352
        Thanks Jim! Testing it and the hold is strong, so it may work really well.
        Matt, it is Formlabs grey. Pretty strong stuff. It is durable, I have some gears that I have been playing with that are holding up fine. I have soaked it in water and STP oil and no reactions that I can see. It can be brittle is impacted. Drilling is doable, but may chip near the edges of the holes.
          • 342
          That looks very interesting. The magnets are strong enough to use on rudders and dive planes in a small sub?
            • 2352
            Bob, I believe so. How about I send this out to you for you to test?
              • 342
              I'm Sure I can find something to put it in and test. Have water in my pool already for sub testing. Do you have my address or do I need to send it to you?
                • 2352
                To be safe send me the address. Thank you, I will send it this weekend.
