X-tail linkage options
  • hampboats
    • Nov 2005
    • 205
    I could use some options on the best method of doing the x tail linkages for the Walrus sub. I have tried a couple ideas, but I need something more proven. Please include photos. If you can't upload them here, please send them to dhampton@ameritech.net. Thanks
    • 2349
    When I get home tonight, I can upload my Walrus setup.
      Dave,
      ....not sure what aspect of an X-tail you are looking for. See if this helps...it's an image of the interior of an Engel Type 212a. It's not really different from a standard cruciform tail, just rotated 45 degrees.
        • 2349
        What Jeff showed you is one way and a great way. What I did on mine was mimic a builder who I call the Architect. It is tough to say "best way" is. If it works for you, that is the best way.
        Here is Will Oudmayer's Walrus setup.
        Here is mine,
        These go to the push rods from the WTC
        Look carefully, the horns of the opposite side go in the same direction.
        I hope this helps.
          This also may help to show how the tail feathers move as it's not always obvious to someone who is building an X-tail for the first time.
          btw: links = left, rechts = right, hoch = high (up), runner = down
            • 341
            My 2 X-tails, a Albacore and a Sea Dragon are hooked up like standard subs and then I use a mixer, think both came from Mikes Sub Works. There are other mixers around, Bob Martin may still have one left from his sale items. Think a throttle mixer will work as well.
              • 2349
              Bob,
              It is a standard setup hardware wise! The peace missing is the x-tail mixer.
              Good points that both Jeff and Bob brought up.
              • hampboats
                • Nov 2005
                • 205
                Can you use a UPC-1 on an X-tails, and if so, which servo?
                  • 2349
                  It is connected between the receiver and the x-tail mixer on the servo that you use to dive.
                  • gantu
                    • Aug 2009
                    • 145
ID:	132247Click image for larger version
ID:	132248Click image for larger version
ID:	132249Click image for larger version
ID:	132250Click image for larger version
ID:	132251Click image for larger version
Name:	Roerbladen hulpmiddel.jpg
                    • gantu
                      • Aug 2009
                      • 145
ID:	132253Click image for larger version
ID:	132254Click image for larger version
ID:	132255Click image for larger version
ID:	132256Click image for larger version
ID:	132257Click image for larger version
ID:	132258Click image for larger version
ID:	132259Click image for larger version
