Gas Fill Valve
  • wgreeley
    • Jan 2019
    • 4
    Gas Fill Valve
    I am rebuilding my old 32nd Parallel Type VIIC and would like to use a gas system. I would prefer not to use LPG or Butane. "Dust Off" and "Super Duster" use a male aerosol valve for their high volume products. Their more expensive products (2X$) use a threaded valve. The only fill adapter I can find is for the screw top cans. Does anyone know of a male aerosolvalve filler?
    You can buy the bottom valve from Bob Martin. You can buy propel or paasche air brush gas at Hobby Lobby or make your own adapter to use dust off. Use a on-line coupon at Hobby Lobby. Too expensive?
    • jure george
      • 361
      Hi
      Can you show what the adapter would look like to the dust off can?
      Thanks
      • tommydeen
        • 327
        Well i used to get duster 134 refill from mG chemicals and it was great but…. They discontinued the refill can(threaded) ugh
        • m. munger
          • 72
          Here is my (RedNeckGineering) solution for the cheap warehouse club non-threaded trigger style canned air:
          A clamp-on tire chuck, brass fittings down to 1/16 tubing down to the standard nozzle tubing, with a valve extender (loose piece).
          NOT pretty. Jam it all together, invert the can and squeeze the trigger, cycle your WTC valve. Almost takes three hands.
          Good luck!
          • cheapsub
            • Feb 2011
            • 200
            Something don't make sense to me.
              Good luck!
              So you just jam the tube of the trigger-style duster into the tube with the red heat-shrink on it? It holds pressure okay as you're filling? I am actually excited about this...
              Bob
              • m. munger
                • 72
                The red portion is a cut-down piece of the tube that came with the can(s). But yes, "jam" that bugger in I did. I was going for Functional (read: dangerous, "own-risk" kinda thing) versus Elegant. To no surprise, it did shoot off once in an interesting (dangerous might be a better adjective) fashion when inverted. Anyone remember the "Propel" tent at the Regattas? As I recall, we're only talking 15-20psi with the canned air products (just enough to warrant a "Don't do this. You'll put your eye out kid").
                Matt​
                  Matt, you inspired me!
                  Looking to simplify things and make them a bit more robust, I sourced a pre-made air hose with clamping nozzle and fabricated an end that actually screws directly into the duster can itself. Threaded, it won't blow out and it seals perfectly.
                  This solution was designed for use with the Office Depot duster cans, but might work with others.
                  Now available here for people not wanting to fabricate their own.
