Trafalgar Class - HMS Trenchant in 1/72 scale - Magnetic End Cap with piston system
    Yeah! Nothing popped off and the sub survived the heat. Now onto a little of the insides.
    The WTC type I will be using is a piston style. Most of the parts will be 3D using my Elegy Saturn and using Fast Grey resin.
    The volume I calculated was 1,000 ml., but I took the weight from the separation line not water line on the 1:1 version. So, I am likely fine with 750 to 800 ml.
    I will be using a magnetic endcap and mostly the same setup I did for the Skipjack.
