OTW Molch 1/9 scale - The multiple rebirths of a classic
  • gantu
    • Aug 2009
    • 148
    Here some pic
    • gantu
      • Aug 2009
      • 148
      Some pictures of the molch.
      • subicman
        • Dec 2007
        • 217
        Thank tou for those pictures Gantu! There are definitely many views that I have not seen yet. I still have time before Groton fun run to make some changes. In fact I was thinking about printing a new rudder, but I was concerned about how robust it would be....
        Tim
        • gantu
          • Aug 2009
          • 148
          Here some more send me your emailadress via pn so you get an dropbox link.
          Gantu
          • subicman
            • Dec 2007
            • 217
            27 April
            Breakfast Club Report:
            MS Molch repairs:
            3D services was obtained and high detail hull parts were printed and installed in several locations, replacing older damaged parts or being installed per plan were the parts were initially left off due to wartime construction demands.
ID:	148414Click image for larger version
ID:	148415Click image for larger version
            Fairweather has allowed for the trades to commence painting of the hull, however the paint system used performed less than ideal and the topcoat is still tacky 3 days later. Paint layup was performed under environmentally controlled conditions, using the proper primer for the topcoat system. Sanding on the faulty coat has commenced and a new paint system has been procured.
            The weapons depot has delivered 2 new weapons for the ship, the paint system used by the depot obviously performed much better than the one used for the hull. Might have to investigate what the weapons depot uses further. The was some debate about what the weapon color scheme was supposed to be, but the depot is assuring us that the supplied weapons are painted IAW the applicable standards for the weapons.
            MS Hecht:
            Standing ready for sea-trials and initial operations for the season.
            Typ XXIII U-4712:
            Further materials have been procured. Work on this project has been on and off over the last few weeks as trade efforts have been focused on MS Molch repairs. Outside shipyard commitments have been progressing and completions points are clearly defined in the near future, thus freeing time and resources to continue this project.
            Tim
            VP of Model Shipbuilding
            • subicman
              • Dec 2007
              • 217
              5 May
              MS Molch Project:
              Paint trades got a good crack at the first re-coats of the hull on Saturday morning and continued into Sunday. Results were much better this time around. Weather hindered any further painting for the week though. The color shades initially laid down on Saturday were not of the right formula per the specifications, but the correct shades were located on Sunday and the results are good. Hull painting to recommence at next break int he weather.
ID:	148419Click image for larger version
ID:	148420Click image for larger version
              MS Hecht:
              Awaiting initial launch.
              Typ XXIII U-4712:
              U-4712 project work has remained static as all resources have been allocated to Molch repairs and outside shipyard commitments. New tooling has been procured for use with this and further projects, awaiting delivery.
              Tim
              • subicman
                • Dec 2007
                • 217
                12 May
                MS Molch Project:
                Unexpected good weather over the weekend allowed the paint trades to apply several top coats followed by sanding. Protective topcoat was applied and paint trades have concluded the bulk of their work.
                The riggers were able to mount the weapons after the paint system cured. This evolution went with out incident and the riggers went on to reload the shaft and prop into the hull.
                Work remaining to be completed is the battery compartment mounting, some rudder work to include possible configuration changes and rudder preservation. Control linkages are being refreshed and lubricated. Command module top-load will be the final overhaul item prior to weights and moments running a check on buoyancy and ballast
                MS Hecht:
                Status is the same: Awaiting initial launch and seatrials. The cover was removed from the training basin, however the training basin is in need of repairs this season. Components have been procured.
                Typ XXIII U-4712:
                New 3D manufacturing tooling has arrived, Alignments and initial operational check in progress. It is larger than the current in operation machine. The build area is big enough to do nuke hulls in sections and diesel hulls in half sections
                Tim
                • subicman
                  • Dec 2007
                  • 217
                  17 May
                  MS Molch
                  Control linkages are to be refreshed. New components have been sourced and will be received by 10pm on 5/16.
                  Paint trades finished cleaning the failed paint system from the rudder and painting and preservation was commenced.
                  MS Hecht:
                  Test tank has been repaired and refilling has commenced. Water loss was substantial (~ 16"), however water fill has been progressing at at rate of approximately 4" over 12 hours, estimated completion time is Wednesday 5/17, however tank may be of sufficient volume to perform.
                  Sea trials by 5/16.
                  Typ XXIII U-4712.
                  New construction has halted until after SubEx 2022. New 3d manufacturing device has been installed and leveled. Resin cure calculations in process.
                  Tim
                  • mickm
                    • May 2004
                    • 102
                    Looking "AWESOME" Tim. Great looking paint scheme too.....
                      Originally posted by subicman View Post
                      17 May
                      MS Molch
                      MS Hecht:
                      Sea trials by 5/16.
                      Typ XXIII U-4712.
                      Tim
                      what Type XXIII are you building? OTW? Bronco? Just curious...
                      • subicman
                        • Dec 2007
                        • 217
                        Sam,
                        Building an OTW kit I have been sitting on for a few years.
                        • subicman
                          • Dec 2007
                          • 217
                          Alright, been a few weeks. Wife had me working on a bathroom project and the Groton SUBEX2022 was over the weekend of May 21/22. The report from the SUBEX is that HECHT ran really well and MOLCH had a few issues the ended in a mud dart incident on Sunday. The ballast pump tube came off the end cap of the OTW cylinder and the engine room and the forward compartment flooded. In addition, a previously un-noticed crack in the battery compartment made itself evident via flooding in that compartment also. Repairs are underway, and a new battery compartment case was ordered and has been received.
