Type 9 build and operation review
  • Filter
  • Rick Teskey
    • 213
    good day
    Has anyone built and operated the 1/72 Revell type 9?
    Interested in preformance review and cylinder required.
    Rick
    • 1364
    Rick,
    That boat takes a 2.5 SubDriver. I have one in stock.
    It handles well. Turning is decent with those twin rudders directly behind the props. I’d anticipate perhaps a 15ft turning diameter, depending on how you set up your linkages.
    Bigger than the T7, so more room in the hull for fat fingers, too.
    Bob
      • 331
      Rick, I have one with the sub-driver and fittings kit. Like Bob said, much easier than the type7 to build and work on because it doesn't have the saddle tanks. I'd like the turning radius to be better, the setup doesn't turn the rudders as much as I would like. Plan to change that before too long.
      • redboat219
        • Jan 2005
        • 519
        Bob,
        Any chance we can see a video of her?
        Also, in your opinion, which is a better handling boat, the 1/72 Gato and Type IX?
        • Rick Teskey
          • 213
          Thank you for the info and pix
            • 331
            Well, neither one is fast but run at reasonable speed. The type 7 turns better right now but the Type 9 can be easily changed for more rudder movement. The Type 9 has 2 torpedo tubes installed in it but I have not made them operational yet. Sticking the sub-driver in the Type 7 and connecting up the 2 shafts with long tweezers is a huge pain in the butt, the Type 9 is just a little tedious.
