Hello
I am thrilled to anounce this new WTC that is expandable to any lenght you might need by just adding on sections as easy as twisting a cap on!
And just as easy to open.
Made from the same materials that scuba underwater camarra cassings are made from and space age sealing tecknology and preciese molding comes this unique interlocking system of making a WTC.
The large tube measures apoximatly 12 inches by 4 inches OD with a 3.00 inch interior diamiter.
The smaller one is 5 in long,when locked in place with the 4 locking bayonet lugs a snug fit is made and there is no internal ridge or gap.
The seal is not an O ring but a special kind of seal that alows for lateral thrust and is made to withstand seveare exposure to asids.Placed on an internal shoulder ridge with a grove .It is also replaceable.
The caps come in a variaty of shapes depending on the function required and also have the same seal if used on the male side of the tube.
One cap even has a seperate smaller cap for rapid draining or acses without removing the main cap ,for lets say the main switch .
I can build for you a custom WTC with the motor or motors shown and cooled or not ,with all the components necessary to run a pump operated ballast system with your radio gear installed and tested to 30 ft ,starting at 280.00$ depending on number of motors and acessories.
Or I can supply the raw WTC components ready for you to build as you like.
The reason I like this WTC are the following.
Engineered not to leak under the harshesed conditions either from the outside or from the inside.
High qualty construction and materials far serpass requirements for RC submarines and are in the realm of Millitary speck equipment.
Easy to expand and interchange with other internal trays intendid for other subs.
If you break one its no big deal ,your back in the sea at no time!
Parts readily available,no special toolling required in the WTC walls or caps.
1/4 inch thick walls!
Positive locking bayonet system.
No stress tranmitted to the internal tray which is a problem on other WTCs.
Chemical and thermal resistance is very high especialy usefull in pools with clorine that distroy seals.
And its clear.
I can see this WTC becoming the future one of choice for our hobby.
Let me know I am taking orders.
I have many parts on hand to keep your fleet running well into the future.
thanks
For more info please call me at 1-352-351-2547 6 to 8pm EST.
Will ship world wide.
Dave
And its clear.
thanks
Dave
