BowPlane Interlock
  • KevinMC
    • Sep 2005
    • 463
    BowPlane Interlock
    New product announcement: Bowplane Interlock
    The BowPlane Interlock is made for solving a problem uniquely found in model subs with retractable bowplanes: Many retractable bowplane mechanisms will bind up or even be damaged if the planes aren't precisely positioned during the retraction/extension cycle. The BPI solves this problem by sequencing and controlling motion for both the bowplane pitch and retract servos. Upon command to retract the planes the BPI assumes control of your bowplane pitch servo and forces it to a user-defined "clear to retract" position before initiating any movement in the bowplane retract servo. The retract servo is then cycled from the extended to the retracted position and drive commands to the pitch servo are shut off. For added realism the retraction/extension cycle is done at one of three user selectable (slowed) speeds. Until the planes are completely extended again all pitch servo commands are blocked by the BPI. Upon command to extend the planes the reverse sequence occurs - while the planes are slowly extended the pitch servo is once again held at the "clear to retract" position, when the extension cycle is complete control of the planes is returned to the user commanded position.
    The BPI can be seen in operation here in Bruce Martin's Revel Gato. A retraction/extension cycle is demonstrated with the planes deliberately left in the full-rise condition to show how the BPI overrides the commanded position during retraction/extension.
    The BowPlane Interlock is available from KMc Designs for $35USD. Contact by PM or email KevinMc.Electonics[at-sign]gmail.com.
    KMc Designs
    • 848
    Way cool, Kevin!!
    B^)
    • bharris
      • Jun 2004
      • 103
      That is great Kevin you just solved one of my problems with installing retracting bow planes on my 1/48th scale USS Seadragon, the planes have to be at about 30 deg down before they can be retracted. It was either try to remember, micro switches or let an auto depth control circuit do it if it can be adjusted properly.
      Bob.
      • southern or
        • May 2014
        • 484
        Yeah, that looks great. I might need one for the Typhoon. The Oscar is going to be fixed.
        • KevinMC
          • Sep 2005
          • 463
          Thanks for the kind words all. Like many others this product is something that was born out of necessity - As many are aware I've been working on a pressure-based depth controller for my OSCAR for a long time, and I needed a way to positively lock out the bowplanes pitch servo in case I left the controller active when the bowplanes were retracted. Solution: BPI!
          @Bob - Yes, the "safe to retract" position can be defined as any position within the working range of the planes, so setting it for 30 deg down for retraction is no problem.
          For anyone who's going to be at the Carmel Fun Run I will have a bunch of these with me for show and sale.
          KMc Designs
          • bwi
            • Jun 2013
            • 205
            That's is great stuff Kevin congrats!
            Grtz,
            Bart
            "Samuel Smiles"
