SHAFTS
  • subshop
    • 51
    SHAFTS
    I have been looking for shafts for a 32p gato i just purchased and i cannot seem to find a vendor that carries a 36" - 3/16" shaft with a threaded end. any help is appreciated . neil
  • rokket
    • 64
    Try these folks, they do
    Try these folks, they do brass props and accessories (and their stuff is sold thru others too):
    • subshop
      • 51
      SHAFTS
      rokket, checked it out and nothing nearly long enough. also they only list metric ! appreciate the help though, neil
      • dietzer
        • 255
        Subshop,
        I recommend that you get
        Subshop,
        I recommend that you get a 36" brass or SS 3/16" rod and just use a die to thread the end. Home Depot and/or Lowes will probably have what you need (in brass, probably not in SS).
        Hope this helps,
        Carl
        • subshop
          • 51
          SHAFTS
          threading a shaft would not be the problem but i'm worried that when i clamp the rod to thread it may leave marks on shaft but maybe i'll try anyway, thanks neil
          p.s. i thought i could eliminate one more step to save time!
          • fgauer
            • Mar 2007
            • 6
            Hi...
            McMaster Carr has 36" lengths
            Hi...
            McMaster Carr has 36" lengths of stainless rod in several types. They'll take credit cards as well.
            Cheers,
            frank Gauer
            Tustin, CA SC1910
