Sub-Driver 3.5 mod 2 -- **SOLD**
  • ericpw8818
    • May 2003
    • 81
    Up for grabs is a Sub-Driver 3.5 mod two from Caswell. The system is set up for snort operations. Included is the following:
    Sub-Driver 3.5 Cylinder with two motor end cap
    Two Standard Futaba servos
    Large Snort system with controller
    ADF2 Angle Driver
    SES-II switch
    Y-harness
    4 cli-con connectors
    This unit was the kit which was assembled and never completed. I am moving on to other endeavors and have to let this go. I will include shipping in the US.
    All Paperwork will be included. Sold as is. PayPal preferred. Please Email me: EricPW8818 (at) aol.com
    Asking $450
    Thank you
    Eric
  • ccontrol
    • Mar 2012
    • 186
    Re: Sub-Driver 3.5 mod 2
    What's the capacity of the ballast tank?
    If you're not sure, tell me the inside dimensions of the tank.
    Thanks!
    • ericpw8818
      • May 2003
      • 81
      Not sure of capacity but it is 8 1/2" long inside.
        Given a length of 8.5 inches and an internal diameter of 3.25 inches (wall thickness is 1/8th inch?), then the volume would be 70.5 cubic inches.
        volume = pi * radius-squared * length
          • 2353
          The battery compartment looks really small, what was this going into?
          • ericpw8818
            • May 2003
            • 81
            The subdriver was set up with the battery terminals
            Heading to the wet space in the hull. The forward compartment
            Is a void space for more air for the snort system. This was
            Going in to a 1/96 Oscar so there needed to be some extra
            Volume.
            Eric
            • ericpw8818
              • May 2003
              • 81
              SOLD
