1:35 XXIII by BRONCO
    • 2359
    #31
    Re: 1:35 XXIII by BRONCO
    Sub-Driver has it: http://www.sub-driver.com/models/sub...submarine.html
      Thanks for the link. I didn't think they were going to carry the kit.
      Just ordered one.
        I was able to put eyeballs on the Bronco Type XXIII kit that Jim Butt received this past week. (got it from a different vendor, so they are definitely out there!)
        This is a very nicely detailed kit and as best as I could tell after a short 'fondling', an accurate kit. (there are one or two things I might argue about) Converting this kit to be an r/c runnable sub will likely be a very common thing for folks to do and doesn't look like it will be difficult to do. I know that Jim is looking to make his operational.
        I'm looking forward to seeing what folks builds look like, both static and r/c. I may just have to pick up a kit for myself!
          Jeff-
          What things do you see as being inaccurate? (One thing I've read about so far is the prop...) Just wondering...
          -Sam
            Hi Sam,
            The other major item are the upper bow free flood vents which are mirrored port and starboard. The photos that I have and the drawings show them as staggered by a frame. Check out the scans that I shared with you in my Dropbox.
            There are a couple of other items that I need to verify, but they are really minor.
              Hi Sam,
              I haven't seen the model yet, but that's the way I recall it as well. They are offset from one side to the other. Easily fixed.
              Yeah, I gotta print them off. I've got to brush up on my references.
                • 2359
                #37
                Jeff,
                Are you willing to share the pictures?
                  Got mine today. Holy crap is it a large model. I haven't had time yet to look at all the parts, but so far, it looks like a pretty nice model.
                    I'll need to go figure out which book they were in and get them scanned. Give me some time, but I will.
                    • warpatroller
                      • Feb 2006
                      • 308
                      #40
                      Both of my kits arrived last Tuesday. One kit has the bow and stern halves fitting together perfectly! On the other kit, the stern halves do not mate up properly. Bronco wrapped the hull halves with rubber bands. This may have contributed to the misalignment on my one pair of stern pieces. One stern half was compressed/squeezed inside the other half when I opened the box. It will make it a bit more challenging to get them glued together properly..
                      I believe an online reviewer, of the kit, experienced the same issue with the copy he received for his review..
                      • warpatroller
                        • Feb 2006
                        • 308
                        #41
                        Below is a leaked photo that was taken recently, at Arizoniawerft, showing two Typ XXIII hulls suspended by cables from some sort of heavy lifting crane rig..
                        There is apparently some sort of U-Boat construction activity going on in AZ.. It is unknown, at this time, as to when these boats will be completed, or where they will end up patrolling..
                        Two sinister looking sisters, hanging in waiting.. I wouldn't want to be on any of the ships that encounter these bad-ass, beyotches at sea..
                        • modelnut
                          • May 2003
                          • 432
                          #42
                          I've started my kit. Finally decided that I will never be able to afford to build her for RC so I may as well just build her static. The kit did, after all, cost $100.
                          Looking ahead, there is not much about the boat's running lights. I thought about wiring them up and replacing the clear parts with LED's. There appears to be one light forward and aft in the port and starboard light housing. All the instructions say about them is "Clear". That can't be right. What color were they?
                          - Leelan
                          • modelnut
                            • May 2003
                            • 432
                            #43
                            BTW, there is a great build going on here: http://www.modelshipwrights.com/modu...73&ord=&page=1
                            - Leelan
                              - Leelan
                              On the tower, the lights on the sides behind the clear lens cover were green and red.
                                I'm doing this one up R/C...I still may buy another one for static display....
