The Two Conning Towers
  • jess
    • Oct 2004
    • 50
    Some pics of a couple u-boat towers I'm working on, U-302 and U-253.
    U-302 is waiting for a gloss coat and I can start weathering her.
    U-253 is still in progress.
    Both have some scratchbuilding and the kits, WEM, Eduard & Modelbrass.
    Take Care,
    Jess
    http://homepage.mac.com/jess13/PhotoAlbum63.html
  • gerwalk
    • Dec 2004
    • 525
    I like the yellowed stripe
    I like the yellowed stripe training sail. Good job!
    • tabledancer
      • Feb 2005
      • 573
      Jess,
      What have you been doing
      Jess,
      What have you been doing to extend your periscope shears,I like that look and I know it`s rite Also is the one with the yellow stripe a stock c/t.Everything is lookin good Check out Nautilus Models for their newTurm II Wintergarten conversion kit,you`ll like it!
      TD
      • jess
        • Oct 2004
        • 50
        Hi Mike,
        For the sky scope
        Hi Mike,
        For the sky scope I've been using brass tube.
        For the attack scope, I shave off the kit "stands" and wrap a piece of evergreen strip around the base. I then take 1mm thick plastic and wrap that around the evergreen. Putty and sand the seam. Sand the base down til it's the right height. I then add a 1mm disc at the base.
        The yellow striped CT is mostly stock with scratch and AM additions. It started as out of box, but I couldn't help my self.
        I have seen the Nautilus Turm II. Not bad. Good base to work on.
        I wonder what the Revell one will look like.
        Take Care and thanks,
        Jess
