Modifying the USS Andrew Jackson (Revell)
    • Sep 2026
    I am preparing to build the 1/200 USS Andrew Jackson from Revell. I would like to use the clear hull section from an old USS Thomas Jefferson kit that is available by auction. I know the subs are of different classes (Lafayette vs Ethan Allen), but would it fit?
    Any help would be appreciated.
    Thanks,
    Spike_57
  • mike byers
    • May 2003
    • 103
    Obviously they must have the
    Obviously they must have the same scale to begin with.
    The lower hull may be the same diameter 33', but - the upper hull has a different configuration. These are two different classes of boat.
    But it all depends on how accurate the kits are, so - it may work.
    Unfortunatly you will just have to try.
