Bronco 1.35 XXIII with interior
    Well done sir! That is getting better and better.
      Hope they has a guard around those belts as you run by to the toilet.
      • drschmidt
        • Jul 2014
        • 424
        Around the belts yes, but not around the prop shaft...
        Found a basic drawing of a Dräger circulating blower. This is one installed in a Type IXc, but similar ones were also installed in the XXIII boats.
ID:	133931 Click image for larger version
        • drschmidt
          • Jul 2014
          • 424
          Puzzle work....the rudder works via a thread drive. The respective crank rods are a pain to fit in. Had to re-design the ventilation tubes more than one time.
          • drschmidt
            • Jul 2014
            • 424
            Added the stern hydroplane drive. Again a rotating shaft drives a gear that re-directs the rotation downwars by 90°. A threaded drive then translates the rotation into an up and down movement that is then re-directed via a deflection lever towards the plane itself....tricky.
            • drschmidt
              • Jul 2014
              • 424
              Started experimenting with my new 3D printer. Some t-frames for first fitting tests. Quite pleased with it...
              • drschmidt
                • Jul 2014
                • 424
                Continued printing 3D parts, this time for the Diesel. The motor block took severeal tries, but now I have everything in shape....this is as printed without cleaning up. Going to be good.
                • drschmidt
                  • Jul 2014
                  • 424
                  Fuel lines and the pusch rods for the rocking levers....tedious.
                  • drschmidt
                    • Jul 2014
                    • 424
                    Lots pof smaller parts attached, cooling water, oil and fuel pump, oil filter, cooling water manifold for the block, exhaust, rpm meter, throttle....
                      There only so many ways to say "WOW", I think you created a new way.
                      • drschmidt
                        • Jul 2014
                        • 424
                        Continued drawing.....clutch assembly. The problem is that photos depicting the interior of the Type XXIII are rare and often not quite clear. Anyway, that's what I found out. Clutch was driven by a manually operated worm gear with a detachable crank. This is my basic approximation. Details to be added....
                        • drschmidt
                          • Jul 2014
                          • 424
                          Designed the belt drive clutch fpr my Type XXIII based on a similar one from the Type XXI (had the drawing of latter). The main clutch and the belt drive clutch were coupled, so that one could only engage the belt drive wehn the main clutch was open. A lot of geusswork on my side involved, as there are now drawings or photos of this section. But I like it....getting busy in there.
