Bronco 1.35 XXIII with interior
  • drschmidt
    • Jul 2014
    • 424
    Afetr finishing the Trumpeter VIIc I need a new challenge, and I just love those cut away boats. I decided to get a 1:35 Trumpeter Type XXIII boat and build the interior from scratch. So I started to design the whole boat in 3D CAD, beginning with the diesel Enigine an teh main electric motor.
ID:	137896Click image for larger version
ID:	137897Click image for larger version
ID:	137898Click image for larger version
ID:	137899Click image for larger version
    Another excellent project! This will be enjoyable.
      Looking good!
      • drschmidt
        • Jul 2014
        • 424
        Completdt the drive train with stuffing box, thrust bearing, the belt drive with the creeper motor, the main clutch, e-motor, Diesel clutch, and the Diesel motor. Now fitting everything into the virtual pressure hull. Tedious but until now, only minor corrections needed.
Name:	Screenshot 2019-12-28 at 15.58.39.jpg
          Wow, that will be impressive!
          • drschmidt
            • Jul 2014
            • 424
Name:	Screenshot 2019-12-30 at 14.09.08.jpg
            Hull strcuture and electric switch panel done...getting cramped in there.
            • drschmidt
              • Jul 2014
              • 424
Name:	Screenshot 2020-01-01 at 14.38.58.jpg
ID:	133862Click image for larger version
              Oxygen bottles, compressed air bottle, Diesel exhaust valve, electric cooling water pump added...
              • drschmidt
                • Jul 2014
                • 424
                Added the blower for the room ventilation. Here starts the guesswork because plans and descriptions are not clear about position and size. Also added the first sketch of the air induction and the air exhaust masts. Again, plans are not coherent...again, some room for guessing.
                • drschmidt
                  • Jul 2014
                  • 424
                  Added the blower for the room ventilation. Here starts the guesswork because plans and descriptions are not clear about position and size. Also added the first sketch of the air induction and the air exhaust masts. Again, plans are not coherent...again, some room for guessing and painfully slow reconstruction from some bad photos....nevertheless, getting there:
ID:	133875Click image for larger version
                  • drschmidt
                    • Jul 2014
                    • 424
                    Found some photos of the induction masts which booked me into a complete redesign of the masts and the respective piping. Again, allot of guessing, but the green pipes are according to the ventilation plan and comply with the pics...tedious.
ID:	133889Click image for larger version
                      Excellent 3D CAD skills!
                      • drschmidt
                        • Jul 2014
                        • 424
                        The current status with added diesel airbox....
                        • drschmidt
                          • Jul 2014
                          • 424
                          More detail work. With the help of the iron plan of the Type XXIII I added the machine bases and floor. On the starboard side, benath the floor plates and parallel to the Diesel was the lubricating oil tank.
                          • drschmidt
                            • Jul 2014
                            • 424
                            The creeper motor support.....elegant solution they found back then:
                            • drschmidt
                              • Jul 2014
                              • 424
                              Working on the toilet...a special one that was emptied using compressed air.
