The 1:100 Project 941UM Typhoon Build Thread
    Re: The 1:100 Project 941UM Typhoon Build Thread
    Are those red LED's?
    If so, why? BD.
    • Wheelerdealer
      • Jun 2006
      • 315
      No those are the Posilock connectors. I have used them before getting electrical cables through bulkheads before and they work well. Pressure tight too.
      • vasily
        • Jun 2014
        • 42
        Very clean build. Those PosiTite connectors are new to me, and I want them! I notice that the smallest size PosiTite is rated for wire gauges 20-18, and I bet that your wires are smaller than that. Do you do anything special to the smallest Positite to seal round smaller wires, do you use 20 gauge wire as a minimum, or do the standard PosiTites work fine on smaller gauge wire?
        • Wheelerdealer
          • Jun 2006
          • 315
          Opps sorry wrong picture. I am using the new tiny red Posilocks Minis. Have put a drop of silicone sealant to make it water tight (for electrical purposes), but there is hardly any cross current in fresh water if you maintain some separation between the connectors. Not really suitable for connections that need to be made and broken often if you use silicone.
            Thanks.
            Interesting item. BD.
            • Wheelerdealer
              • Jun 2006
              • 315
              Bonding the WTBox into the lower hull is probably the most important step in building this model. Naturally the box needs to be level and at just the right position so the motor output shafts line up with the prop shafts (though if you use universal coupling rather than the ridged couplings supplied you have a little leeway). However more importantly if the box is bonded in too low you won’t be able to get the piston tanks in, and if it’s too high you won’t be able to submerge from a scale waterline. The instruction say that the top of the box should be 26mm from the top of the lower hull, and its well worth measuring this a few times.
              Once I got the water tight box into a position I was happy with I spot glued it in 4 places to hold it whilst I went about bonding it in with Polyester resin.
              • Wheelerdealer
                • Jun 2006
                • 315
                The WT Box bonded in.
                  <<Originally posted by "Wheelerdealer">>
                  I finally found the energy to clear up the garage now the weather has got better and get down to cutting out some of the bigger holes. Hopefully I can some regular work done from now on.
                  • Wheelerdealer
                    • Jun 2006
                    • 315
                    • southern or
                      • May 2014
                      • 484
                      I've been meaning to ask, what all have you done to the WTC? Looks nothing like the two stock ones I have also, how much ballast are you using?
                      • Wheelerdealer
                        • Jun 2006
                        • 315
                        Some more work....
                        Do we all read the same books?
                        • Wheelerdealer
                          • Jun 2006
                          • 315
                          Still a bit more work to do on the hatches....
                          • Wheelerdealer
                            • Jun 2006
                            • 315
                            #28
                            • Wheelerdealer
                              • Jun 2006
                              • 315
                              #29
                              Haven't done much for a few months. I'll get back on it over the winter.
