water sensor - sensor to pump control
  • boatbuilder1
    • 386
    I am looking for a small compact water sensor to turn on a pump is there a devise available I thought there was a schematic in the bruggen book but no dice I just want a simple device to turn the pump on incase there is a leak is there a device or home brew remedy for this
    thanks ca
  • koeze
    • May 2003
    • 204
    Do a google for water
    Do a google for water detector circuit. There must be tens of them around suitable for your needs.
    EJK
    • dietzer
      • 255
      If you'd like to just
      If you'd like to just buy a solution, check out the following]http://battlersconnection.com/html/wireswitches.html[/url]
      Carl
        You may want to take
        You may want to take a look at the Dive manager built by model controllers.
        This device has a built in water sensor, propotional ESC, servo valve control and failsafe. It's primarily designed for use with a compressed air ballast system, but can easily be adapted to work with a water pump instead.
        They used to cost about £27 direct, and I think they're still available at that price.
        Cheers
        • dietzer
          • 255
          Here's a simple, build-it-yourself, circuit
          Here's a simple, build-it-yourself, circuit for automatic pump control]http://www.eskimo.com/~phill/wcc/wctech03.htm[/url]
          Carl
          • boatbuilder1
            • 386
            thanks guys realy helpful I
            thanks guys realy helpful I have to make it myself sas little room in the krick uboat
              Well if you can make
              Well if you can make something smaller than the model controllers dive manager, I wish you luck.
              Mike uses surface mount componentry in his designs, and the price he charges is less than the cost of the components in my experience.
              The dive manager is only 1"x2".
