Lunar models conversion of Proteus
  • Rick Teskey
    • 217
    • 945
    Re: Lunar models conversion of Proteus
    Rick,
    As I've mentioned to you, I love this, and would really like to eventually have one. Still thinking of molding a larger version? And yes, I'm putting it out there: any chance of selling it as a complete KIT?
    JeffP
    • tsenecal
      so,
      inside the WTC i see a voltage monitor, diving plane servo, receiver, mixer, two speed controls sitting on a plate.
      connectors on the stern endcap for the power cables leading to the pumps.
      receiver antenna connector, diving plane servo pushrod seal, and battery connectors on bow endcap.
      that is where i am confused. there appears to be room below the plate in the WTC for a lipo, but then you have the battery wires on the front endcap.
      where do you put the battery?
      and finally, what are the dimensions for the WTC? i am guessing 2" x 8"
        I believe what you are seeing Tim is a fuse used to power the cylinder on and off.
        But I have been wrong before.
        If so great idea Rick.
        Kill two birds with one stone.
        Add a power switch and fuse at the same time. BD.
          Nice work. How do you find the thrust from the pumps on this smaller model?
          • Rick Teskey
            • 217
            Good Day all
            Yes Dave is right it is a fuse holder/ switch, on future slightly larger model ( 20 inch as compared too this 16 inch) I will use one of Kevin McLeod magnetic mission switch so a couple of less end cap penetrations.
            The pumps I use propel this hull just fine with o head discharge, all the thrust is pretty well straight out the back, I have used these same pumps in 2 different sized flying subs and have great sucess with them.
            I even hacked off the pump section which left me with a sealed motor which I have used direct drive on my Merriman Skipjack and a couple of my Seaviews.
            The pumps I purchased from Princess Auto and they run aprox $15.00
            I have opened up a couple of dead ones and found a motor that is somwhere in the 365-385 rangesame can size but no tell tale markings
            On the Skipjack I ran them on 7.4 lipe with tons of throttel and an apm draw of aprox 1.3a/
            I steer it differentally but on this model no reverse, on the next one there will be room for reverse thrust with 2 other pumps unless I go with a different propulsion system which I am kicking around in the cranium thinking thing.
            I hope a package can be put together for this 20 inch wip but first I have too finish the hull then get the cart behind the horse.
            Rick
              DonO and I purchased some of the pumps to play around with and we are very impressed with the thrust.
              Not bad for the price. BD.
              • tsenecal
                of course....
                you realize that i am a brushless bigot, and i will have to spend countless hours creating a brushless pump setup for mine...
                • tsenecal
                  Rick,
                  was i close on the WTC dimensions? can you give me an accurate size?
                  thanks
                  Tim
                  • tsenecal
                    Rick,
                    this wouldn't by chance be your model?
                    • Rick Teskey
                      • 217
                      Good day all you sub voyeurs
                      Yes Tim, it is one of the first tests last fall, its a shame I did not have a steady hand filming with the tablet and driving at the same time but a first on both fronts.
                      I am only use too drinking and driving ( my sub in the back yard and not on the road... so you kids pay attention, stay in school and stay of drugs)
                      The cylinder is" 7 1/2 "long and" 2 1/2 o.d , 1/8 wall thickness.
                      Rick
